Unread 10-05-2005, 08:06 PM   #1
DIY Installing HID Kit on ZKW's
Required Items:
2 ballasts,
2 HID bulbs,
2 Igniters,
2 15watt (Light blue) fuses
Tools:
8mm wrench
Extendable magnet
A drill
3/4" drill bit
This install is very easy, and probably won't take you any longer than 30-45minutes
I started with my driver side..
Since you are dealing with some expensive bulbs, I would highly recommend loosening your headlights to give you some room to work with, which is what I did. Now I have access to professional aiming devices so the cost of getting my headlights aim is not a worry of mine, but if you do loosen your headlights, yes you will have to get the aimed again.
See how much little space you have to work with...
And how much more is created just by loosening the headlights:
So, that said.. I loosened the driver side headlight and pulled it out just enough to give me some room. Very easy, 3 8mm screws, two on top of the headlights, one between the turn signal and headlight.
Once that done open up the rear of the low beams by taking out the protecting cover, take out the existing bulb and replace it with the new hid one.
Now, take the cover and we'll have to drill it. DO THIS AT YOUR OWN RISKS!!!! I have LOTS of drilling tools so this was easy for me to do....
I first tried to use a wood drilling bit...
Didn't work as good as I wanted it to, BUT it's perfect for starting a hole in plastic...
Then I took out my "MAC DADDY" drill bit
The hole only needs to be ~ 3/4" look at the gasket that is right behind the hid's it should be a bit smaller than it.
And this is what it's supposed to look like drilled and with gasket installed:
Then connect all the wires, unless if you're trying to, you cannot go wrong in this step, and if you do... humm... maybe you shouldn't try this install....
Put the headlights back on, make sure the gaps are even all around.
VERY IMPORTANT
Before turning lights on!
CHANGE THE FUSES!
Since I did it one headlight at a time, I changed the fuses one headlight at a time, if you want to do replace both headlights at once and then start them, then replace both fuses at once:
But just in case:
Your driver side low beam is protected by fuse #11 , and the passenger side one by fuse #12
Now, it's the same exact thing for the other side...
Once you're done with all this, get in the car, and turn those new suckers on and ENJOY:
Unread 10-06-2005, 05:23 PM   #2
Unread 10-06-2005, 05:33 PM   #3
cool, thx Komodo... I think Umnitza also added my DIY on there site
Unread 04-07-2006, 09:29 PM   #4
B_w.
Rate My Car: 62 / 340
Your Ride: turbo e36
i am about to do this. just wondering why you need to change the fuses?
Unread 04-07-2006, 10:23 PM   #5
B_w.
never mind that. dumb question
Unread 04-09-2006, 11:44 PM   #6
B_w.
a few things i wanted to add to this:
- i had 4 screws holding my lights in not 3 - 2 up top, the one under the signal, and one underneath the radiator cover. had to remove the radiator cover to get this one.
- i needed all the room i could get so i just pulled the headlight right out - took it for a short drive and the aim still seemed to be pretty good, might adjust it later but ok for now.
- i mounted the ballasts to the bumper support using double sided tape and then duct taped it down again. i then used the double sided tape to mount the igniters on top of the ballasts and then duct taped those again.
- with the first cover i used masonry bits to drill through the cover. this made a bit of a mess because i just drilled a bunch of little holes and then drilled those out. the hole has pretty mangled and needed to be sanded out a lot. on the second one i used a big 3/4 inch wood bit. this one worked really well. just needed to get somebody to hold it so you can go to town on the cover. this made a very nice smoothe circular hole that needed to be sanded a bit bigger.
- when you put the headlight back in make sure to have all the wires for the signals in the right place. i put the first light back and realised i could not re-atatch so i had to take the whole thing off again
i will add anything else that i think of. these lights are a huge improvement over the regualr zkw's
Unread 09-19-2006, 09:15 PM   #7
pj NCSU
Your Ride: 1998.5 M3
how are the high beams connected? I bought my car with these headlights already installed, but no high beams. Also, the 7.5 fuses are still there and work fine??
Unread 09-19-2006, 09:41 PM   #8
B_w.
your low beam hid's will be better than your high beams with halogens.
Unread 09-20-2006, 08:57 PM   #9
pj NCSU
^ true but I can't pass inspection without them...and my fogs don't work!!
