Unread 03-03-2012, 06:41 PM   #1
metonc
Your Ride: 1997 528i
Coolant gauge temperature
My problem is when the outdoor temperature is above 60 F the coolant temperature gauge holds dead center. When it's below 50 F the gauge drops to the cold blue bar---strange. I'm not sure if its the thermostat or temperature switch. Anyone ever have the same problem?
Unread 03-03-2012, 09:34 PM   #2
Could be the thermostat. When was the last time you changed it? Double check the coolant level and bleed the cooling system in case their is air in the system.
MY 03 325i coolant is leaking & overheating.. PLZZ HELP kurtk E46 4 09-16-2011 08:53 AM
Why coolant is leaking 325iZYX Introductions and Greetings 0 07-13-2011 01:39 AM
E30 Temp Gauge Wierdness twistd6 E21, E30 0 12-09-2010 05:08 PM
1997 740i 'Check Coolant Level' after car is warmed up Beazelbub 7 Series (E23, E32, E38, E65, E66) 0 06-11-2010 05:46 PM
Temperature Gauge Erratic!!!! armstrob E12, E28, E34, E39, E60 1 10-21-2008 07:41 AM
