Unread 04-25-2005, 12:07 AM   #1
B_w.
Rate My Car: 62 / 340
Your Ride: turbo e36
sway bar mounting
would it be possible to weld new sway bar mounting tabs to non m shocks. would this be safe? i dont really want to buy new shocks as i just got my bilsteins last fall. just an idea. want to know if this is possible. thanks
Unread 04-26-2005, 04:55 PM   #2
jrhaile
Rate My Car: 114 / 340
Bumping this up as I don't know and hope that someone will be able to help you. I'll forward this into Les as he's the expert when it comes to Suspension tuning.
Unread 04-26-2005, 06:02 PM   #3
B_w.
thanks
apparently ground control makes a sway bar mounting tab kit for mounting the sways to the struts. however this is supposed to void the warranty on the shocks. how long do bilsteins normally last?
Unread 04-27-2005, 11:08 AM   #4
VANCE
Rate My Car: 143 / 340
Unread 04-27-2005, 06:53 PM   #5
B_w.
modifying the shocks so the sway bars can be mounted voids the warranty as far as i can tell
Signs of abuse, improper installation, broken or bent rods, collision damage or modification. Also, shocks used for racing or in race cars.
anybody know how long bilstein sport shocks last for?
Unread 04-28-2005, 05:02 PM   #6
Also if you are a member of bimmerwerkz, autotechnica might be able to help you, I have heard he knows a lot about suspension, and their setups.
Unread 04-29-2005, 05:10 PM   #7
thekid
Send a message via AIM to thekid
You could weld tabs to the struts... If you are really good at welding. It would hard to do and you would run the risk of damaging the struts. But basically, you are goigng to have to buy new (to you or actually new) sway bars anyway. I would just buy aftermarket sway bars for your car or do it right, by buying either the M3 struts or 92 model struts. I don' think the weight difference would be that great. I wouldn't really trust the weld to hold with the way that I drive or through several auto-x's.
The bilstein sports should last most of forever unless you auto- x your car regularly or otherwise track the car. Most of the people that I know that auto-x their daily drivers (any car not just BMWs) get their Bilstien or Koni struts to last 2-3 seasons. Which is 2-3 years. If you do not put your struts through hell like that, then keep the lifetime warrenty in mind. I don't know anybody that have put Bilsteins on their cars that do not auto-x their car or have had them on their car longer than a couple of years. But I am pretty sure they put a lifetime warrenty for a reason, they wouldn't do it if they were losing money on it.
Unread 04-30-2005, 01:14 PM   #8
B_w.
thanks for the helpful replies
it does sound like its not worth the trouble to remount the sways to the bilsteins and voiding the warranty. i already have eibach sway bars which probably would be too big to be mounted to the the struts. the front is 28mm i think whereas the m3 front sways are 23mm?
thanks again forthe help
M5 Sway Bars installed dinan540 E12, E28, E34, E39, E60 0 03-08-2006 08:15 PM
8 Series sway bars TerryY Tire, Wheels And Suspension Forum 5 08-31-2005 09:25 AM
A Man Goes Into a Bar... komodo Comedy Collection
6 06-13-2005 09:26 PM
MPerformance May Special on JT-Designs Front Strut Bar Jon@MPerformance Bmw Cars For Sale/Wanted 6 06-12-2005 04:36 PM
Sway bars? Rooz Tire, Wheels And Suspension Forum 29 04-25-2005 08:45 PM
