Lighting
Sponsored by: BavToys.com
Unread 02-25-2012, 02:22 PM   #1
koul7
Your Ride: 1997 E39 528i
Flickering DEPO Xenon Angel Eyes
Hi all!
A month ago, I upgraded my stock xenon headlights to a set of DEPO Angel Eyes. Although right from the beginning i had an error indication on the dashboard, the were working well, until this flickering problem showed up.
-When the ignition is ON but the lights switch is OFF, the passenger side halogen lamp (not the AE ring) is flickering, and a sound is also heard from the ballast, with the same frequency the lamp flickers.
-If i switch ON the lights, they work fine, w/o flickering.
-When i switch the ignition OFF, they start flicker again for some seconds or maybe minutes, and then they stop flickering.
I read somewhere about "Xenon HID Cancellers" and an "HID Capacitor OBC Fix" set; would any of these help?
Is there any danger of the lamp being burned due to the high frequency of switching ON/OFF?
Thanks in advance for inputs!
Unread 02-25-2012, 08:38 PM   #2
The stock headlights on a 97 are halogen, not xenon.
Take a read through this and see of it helps:
http://www.unitedbimmer.com/kb-e36-zkwhid.php
Unread 02-26-2012, 05:26 AM   #3
koul7
If the stock headlights were halogen, then one of previous owners changed it to xenon. What i did was to change the whole case of the headlights, without changing the xenon mechanism. Hence, i didn't change any fuse during installation, cause the lamps are the ones i had before.
I also tried changing the fuse after the problem showed up, but the flickering kept going with the new fuse as well. I dis/re-connected the ballast cables, cause i think the problem might be somewhere there, due to the "click click" sound coming out of there, the exact moment the lamp flickers.
Unread 02-28-2012, 12:08 AM   #4
Try hard wiring them in. I hear that usually solves the issue.
FS: Depo headlights w/ angel eyes mpowerd Bmw Cars For Sale/Wanted 3 08-15-2011 07:16 PM
Ebay CCFL Angel Eyes on e39 99' BMW DJKapeesh Lighting 3 03-25-2011 07:50 PM
need advice to get eurolights nd angel eyes blikmmer Lighting 8 01-17-2008 08:13 PM
Might be getting some Angel eyes Rooz E36 65 06-09-2005 07:43 AM
