Unread 09-29-2005, 06:48 PM   #1
Thumbs up DIY Changing NON-M to M bumper
so far am only going to post pics... will put details when I get back
Starting point:
Tools - 8 and 13mm wrench
Screwdrivers
pliers
REMOVING OLD BUMPER (easy part):
First off you need to detach/remove the two moldings that are at each side of the license plate
Once those two are removed, you'll see two 13mm bolts on each side, remove those, they are somewhat tuff, but make sure that they aren't rusted, if they are use some Wd-40 (see picture below)
Also, you'll need to remove 2 screws in the fender well, they are 8mm, it helps if you turns the wheels to get more access to them. And you "might" have some screws on the bottom, they should also be 8mm, get those off too. As you remove the last few bottom ones the bumper will loosen up. All that is holding it is the side hangers, gently pull the bumper forward and it should come off, slowly pull forward, before it hangs down, grad behind it (between bumper and fender covers) and unplug both fogs and both brake ducts, then you're ok to remove it
TAKING OLD BUMPER APART
(hardest part):
I'd like to first say that this is the way that I did it, am sure there are other ways to do it, but I found that this one worked for me best!
First unscrew the fog lights from the back. (I had new brackets, so didn't really care for old ones), but I had to reuse the screws...
Unlike other car makes, BMW ATTACHES the hard part to the bumper it's self... you'll have to take it off. Take all of those black clips off, be careful because you WILL need those again. I used a flathead screwdriver and gently taped on the inside making the tap come out from the top, then with pliers, I gently pull on them, there is quite a few of them, so be patient with them.
Once those are off, the hard/heavy part of the bumper is loose, I noticed mine was dirty so I cleaned it up. If you decide to clean it, keep in mind that you'll have to dry it too...
Then you need to remove ALL the golden clips that you use to screw stuff in. make sure to get the corner ones too, I almost overlooked them. I removed them by tapping behind each on with a flathead screwdriver...
REVERSE (interesting part):
Here is where imagination and memory comes to play!
First thing, slap the big metal piece on new bumper, (this is when you will LOVE polyurethane since it bends and doesn't brake) Try to get it to align with the two middle/lower holes (the ones facing the ground) that the clips go in, and put those two on first (some muscle power is required, lol) then work your way to the outside clips and finally the ones that face the front of the bumper, once you get that on, you're almost home...
Slap all the little golden clips on, then put the fog lights on, and try to have them be flat with the bumper (aiming them basically)
Put the mesh grill on, common sense really...
Here is the part I hate. Unless if you have m3 brake ducts, this part sucks. Your older NON-M brake dust are both bigger and they hook up at a bit diff spot. Use your imagination here.... I made the cuts wider towards the inner part of the bumper and squished the top part to make it fit... was very pleased with the driver side one, didn't get that great a result from passenger side... but how well...
PUTTING NEW BUMPER ON
(enjoyable part):
Well, all that you really need to do is the reverse of the first part, just a few tips though..
test fir bumper first, then let it "hang" by the middle 4 screws and connect fogs and brake ducts (also align the brake ducts)
Start the two most middle screws
Get the bumper into the hangers, and hand tight the two middle screws..
lift/lower the bumper to have a perfect gap and tighten all 4 front screws as you do this...
then look at the gap between fender and bumper, if it's perfect just tighten to two screws in fender wells, if not perfect either pushed down or up on bumper while you tighten those two screws..
And finally get the bottom screws, and VOILA
Unread 09-30-2005, 03:53 AM   #2
Awesome . . . glad you remembered the camera when doing this
Unread 04-06-2007, 11:29 PM   #3
Devo-Dave
Your Ride: 1994 BMW 320i
I learned allot from this DIY tut, I have an m3 replica bar waiting to be painted and want some more info on how you got the non M brake ducts to fit right. Do you have any pic by chance?
Unread 08-11-2007, 08:31 PM   #4
DJ Genius
DJ Genius's Avatar
Your Ride: '94 325i EURO
Send a message via Skype™ to DJ Genius
Too bad pics aren't clear where fogs are fitted.
Unread 08-11-2007, 11:10 PM   #5
Sweet DIY
Unread 08-12-2007, 12:44 PM   #6
why... what u need to do on yours?
Anyone want a brake pad changing DIY? Or a Brake Bleeding one? nick_318is BMW OEM Parts Department DIY's & FAQ's 11 12-23-2005 11:35 AM
E36 M3 Front Bumper Rooz Bmw Cars For Sale/Wanted 10 11-21-2005 10:01 PM
New bumper maybe? Rooz E36 31 07-29-2005 05:59 PM
rear bumper question. EcianIce E46 3 05-05-2005 10:16 PM
