Unread 02-11-2012, 03:32 PM   #1
Brokenbmw1
Your Ride: 1999 bmw e39
Loses power
Hi guys, my car is a 2.8i 5 series auto, from cold its fine but once engine warmed as soon as you switch car off the return and start again it plays up, when turning key it turns over 2-3 times before starting up, you know then its going to do the following, it wont pull, and even on a flat it has no power, if you put in park and rev it sounds like a misfire, popping sound maybe like its sucking air, wonder if this is when starting its sucking the air then thus causing it to run lacking power, you can put your foot down and it still dosent respond, any ideas would be most be most helpfull
Cheers kev
Unread 02-12-2012, 02:51 AM   #2
Have you taken it in to have the OBD system scanned for Codes? Sounds like its in Limp Mode possibly. Other then that maybe a Throttle Position Sensor (TPS)?
Unread 02-12-2012, 07:44 AM   #3
Brokenbmw1
Hi thanks for your reply, havent had codes read yet, was trying to eliminate anything simple first, also dont know if its connected but after i turn off ignition the oil can light stays on but its not red but outlined in yellow, it goes out only after switching ignition on then turning off again, any ideas cheers kev
Unread 02-12-2012, 07:45 AM   #4
Brokenbmw1
Update forgot to mention, dont know if connected to original problem but after switching ignition off the oil light can stays on but isnt red but outlined in yellow any ideas cheers kev
Unread 02-12-2012, 09:29 AM   #5
Getting it scanned is usually free at most auto parts stores. I like to recommend that because it can give you a good base of where to start. In the E34/39/60 section I have posted the link to a copy of the Bentley Service manual which has an excellent troubleshooting and diagnostic guide. They are very handy.
As for the issue with the oil light i have to say I have never herd of that happening and I'm not sure why it's doing it.
Unread 02-16-2012, 11:25 AM   #6
Brokenbmw1
Hi again, i remember actually sometime ago it was scanned and nothing came up, any ideas why or what this may point to cheers kev
Unread 02-16-2012, 12:07 PM   #7
Well their are four essential components to make a combustion engine run. They are:
1. Fuel
2. Air
3. Spark
4. Compression
If anyone of these is missing the car won't run. How was the car running before this? Did this problem occur suddenly?
If you have never changed your fuel filter, spark plugs or cleaned your Idle Control Valve (ICV) now would be a good time. The fuel filter can get clogged up and effect the mount of fuel going to the engine.
Now, one thing to also look t that is really important: how are all your vacuum lines? Check all your hoses and connections for either a lose hose or a crack or tear in the hose. A vacuum leak has been known to make cara run poorly. Vacuum lines are cheap too if it is damaged. But go get a good light and inspect them all. A crack may be very hard to see so look carefully and feel them too. If you need assistance the Bentley Service Manual has some excellent pictures and instructions to help you.
Unread 02-16-2012, 04:55 PM   #8
Brokenbmw1
Thanks for your help, i will try all these tomorrow cheers kev
BMW announces new Power Kits for 135i and 335i scooter BMW News And RSS Feeds 0 09-19-2011 09:00 PM
BMW releases free M Power app for the iPhone scooter BMW News And RSS Feeds 0 01-04-2010 10:30 PM
Microsoft Power Supply komodo Comedy Collection
1 07-13-2005 06:30 PM
