Unread 02-10-2012, 08:53 PM   #1
theeflash1
Your Ride: 320 e46 Coupe auto.
Exclamation Car sill a not starter.!
Hi There...Removed the SPARK PLUGS and they were "Dripping" with Runny oil except the 5th one. Can anyone tell me hhat the hell to do!....Please....
Seemed that I had a 3/4 CHARGED BATTERY-AFTER a few attempts to start car I Could see battery was dying-came out to star car again NO POWER FROM BATTERY AT ALL!........ ..........
Ken.....
Unread 02-11-2012, 10:11 AM   #2
You have a couple of things going on here, but neither one if them is likely very serious. Was the oil on the top part of the spark plugs or down on the inside? Oil on the middle to upper part (where the wrench fits on) means a leaking valve cover gasket. Very common and not difficult to replace. You can do it.
In theory, oil is a non-conductor. In practice, old dirty oil will short out your plugs and keep the car from starting if it gets deep enough in the plug recesses. You may want to buy new rubber boots to fit on the coils rather than trying to clean the oil off the old ones.
The battery is another matter. Lots of short trips, lots of attempts to start the engine, an old worn-out battery, or problems with the charging system. The original battery in this car will last 4-6 years, depending on the climate. Replacement battery will last a bit longer if you get a good battery with plenty of capacity.
Unread 02-12-2012, 08:52 AM   #3
theeflash1
Thank you my friend.....This is doing my head in. So plugs out.....Going to use new ones. How should i clean out engine casing that holds plugs?....Car left for a day...
Unread 02-12-2012, 10:38 AM   #4
It is not really necessary that the holes where the plugs go be completely clean and dry. You can wait until you are replacing the valve cover gasket to clean them well. They will be more accessible then.
If there was a lot of oil in those holes, it ran down into the cylinders. It would be wise to crank the engine while the plugs are out to blow out any excess liquid so it does not damage the engine when you crank it.
You should clean or replace the rubber boots that attach to the coils and fit over the plugs. Something like aerosol carb cleaner and a rag would clean them. If you use that, wear rubber gloves.
Alpina 318i....explain this to me delmarco E36 64 12-20-2014 07:17 AM
BMW Art Car and all-female Ford GT out of Le Mans scooter BMW News And RSS Feeds 0 06-12-2010 06:40 PM
So here's the Plan (RHD Car) Chris United Off Topic  **FOR MEMBERS ONLY** 18 07-28-2006 12:51 PM
What Car Did Your Father/Parents drive or have driven? delmarco United Off Topic  **FOR MEMBERS ONLY** 8 09-18-2005 01:17 AM
