Unread 01-20-2012, 11:45 PM   #1
Miamistylezs
Your Ride: 2003 745LI
2003 745LI overheating
I need help. My 2003 745LI is overheating. The fan is working fine, I filled up the fluid, what should I do next? My heat is not working as well.
Unread 01-21-2012, 02:40 PM   #2
Welcome to United Bimmer! Was the coolant level low? Since you added coolant you need to bleed the air out of the system. When air gets into the system it prevents the coolant from circulating which is a leading cause of overheating. I'm not to familiar with the 7 Series but their should be a bleed screw next to the expansion tank. You'll need to have the heat controls on full hot and run the engine to get it to normal operating temp. Periodically opening the bleed screw to let air out. If you see little air bubble it means their was air in the system. Go until you only see coolant their. It may be benificial to lift the nose of the car a few inches to help the air rise to the top.
Also check for coolant leaks under the car and at all hose connections. The coolant hoses wear out over time. Let us know of this helps.
2003 bmw 235i overheating need help!! XxluixX BMW General Discussion 1 02-29-2012 07:38 PM
E36 328i 1998 Mystery Overheating.. bmw328i98 E36 7 12-21-2010 12:29 PM
Please Help me and My 318is overheating and very low idle Serge E36 2 03-10-2010 08:38 PM
E39 Overheating jay E12, E28, E34, E39, E60 10 03-04-2008 09:08 AM
Windows 2003 - Kentucky Version komodo Comedy Collection
1 10-05-2005 11:39 AM
