Unread 09-19-2005, 02:45 PM   #1
The Ultimate E36 Common Faults FAQ
This is an attempt to compile as much of a list as possible about known E36 3 series flaws one might encounter. Keep in mind that these are known issues pertaining to design, production, or quality control, and in some cases, not necessarily recognized by BMW as such.
A little bit of background on the E36, which covers the '92-'99 3 series models (with some exceptions) . . . According to Bimmer Magazine, BMW E30 (and prior) engineers used complex math equations and heavy field testing to figure out required strength and durability, then they would double or triple the outcome, resulting in a fairly bulletproof car. Not so with the E36, which proved to be somewhat less reliable than the models before or after it, for two main reasons. The E36 is the very first BMW in history to be designed on CAD, and instead of extensive testing, they relied on the program to determine how robust a part or system should be. Secondly, they were engineered with recycling in mind. Which is a bit of an irony, since many owners can make these cars last upwards of 250-300 thousand miles. That isn't to say that the E36 is a shoddy Bimmer- they do more than live up to time honored BMW tradition, as the motors are quite strong, and light years ahead of the E21/E30 powerplants, along with numerous other significant improvements in comfort and performance.
Still, many of them were poorly maintained and abused by previous owners, and as they're currently approaching the higher mileage threshold, you can expect to spend a little money restoring one. But by no means should you not consider buying one, because it's an absolute thrill to drive, and tends to be more reliable compared to other cars in its class, despite its shortcomings. Furthermore, it should be mentioned that while the following list may seem frightening, not all E36's will experience these issues, and since they typically are higher mileage cars nowadays, a lot of the problems have already been addressed by recalls and previous repairs. On to the list . . . .
Engine Bay:
-There is no doubt that the most notorious E36 issue is the water pump. 6 cylinder models up to MY €™97 were equipped with plastic impellers which would break apart and fail prematurely, stopping the coolant flow. Typical replacement interval is 60k, but they€™ve been known to fail at as low as 20-30k, and often randomly. Replacement pumps employ a metal impeller. If you€™re not sure that it was changed, do it anyway. Here's how.
-Clutch fan can shatter and cause extensive damage to the radiator, belts and other parts in its vicinity. A common preventative measure is to remove it using a procedure known as the Fan Delete Mod, but diligent regular inspection of the blades and timely replacement should suffice.
-The stock E36 radiator has plastic necks which can crack or break over time. Even if it looks fine, you may want to replace it, especially near the 100k mark, which is about the typical time when radiators fail. An alternative is to replace it with an all metal unit. The same goes for the plastic thermostat housing, aluminum replacements are available. Again, regular visual inspection is the key to avoiding costly damage.
-The fuel feed hose at the engine fitting can harden over time and cause seepage at that location. BMW€™s recall campaign replaced the hose and clamps.
-Engine ticking can occur, particularly with older E36€™s. This is characterized by a ticking sound (at idle) or the sound of marbles (under throttle) on the passenger side of the engine bay, most noticeable just after startup. It usually happens because engine oil can take some time to reach the VANOS and hydraulic lifters for lubrication. Most agree that this is normal, and is not something to worry about, unless you hear the noise all the time. In that case, the lifters may need replacement. The M50 was notorious for this lifter noise, and in severe cases BMW replaced the motor under warranty. However, on the M42, the problem is usually a failing chain tensioner, a relatively easy fix.
-Rough or poor idling is generally attributed to a dirty idle control valve, or a faulty oxygen sensor. But it can also be traced to the VANOS unit, which can get stuck in the advanced position, requiring a dealership adjustment or replacement.
-On some €™93 and earlier M42 engines, which includes both the E30 & E36 318is, the profile gasket can be eroded by coolant, leading to failure anywhere from 30-70k mi. This is a costly problem since the cylinder head has to come off so the gasket can be replaced with an upgraded version. Although using only BMW approved coolant can help slow down the process, it does not prevent the failure.
-Some European variants of the M52 engine before MY €™98 experienced premature cylinder bore wear, resulting in a loss of power and compression. This was attributed to the sulfur in gasoline, and the only solution is to replace the damaged alloy block. If you suspect you have this issue, have a compression test done.
-Drive belt idler pulley on some E36/M52 models may have been installed incorrectly during production, causing premature wear and eventual failure of the belt. This will occur during the first few hundred miles, characterized by excessive belt noise.
-Throttle valve can get stuck on some models, causing uncontrollable acceleration. This affected 1996 E36€™s (410,000 units), but other years may also apply. The problem lies in both the cruise control and throttle cables, where the plastic bushing on the cable end can break, allowing the cable sleeve to get stuck. BMW issued a recall campaign for this, and the solution was to install a spring steel retainer clip on the cable ends to prevent the outer sleeve from dislodging from the bushing.
-E36/M44 engines may have bad ICV€™s, creating a whistling noise, or causing a hard start or no start condition. The ICV was manufactured with incorrect tolerances between the rotary valve and the housing. The newer updated part number is 13 41 1 435 846.
-M50 engines with VANOS produced 1/92 to 8/94 may have problems starting in cold weather below 46 degrees fahrenheit, or in high altitudes. Symptoms include a check engine light, long cranking times, black smoke from exhaust, and wet spark plugs. When this occurs, the EPROM needs to be reprogrammed by the dealer (MoDiC programming software version 5.1 or higher).
Transmission & Final Drive:
-A faulty guide sleeve on the 1st & 2nd gear may cause the tranny to pop out of gear. Requires disassembly of the gearbox.
-On manual trannies, 2nd gear can completely blow out, or it may refuse to go into 5th gear when cold. Though very rare, this problem is expensive and requires a rebuild or replacement altogether.
-Squeaky clutch pedals are very common, the only solution is to replace the bushings with aftermarket parts, available from UUC Motorwerks.
-Stock transmission mounts can cause excessive vibration or movement, resulting in missed shifts and engine over revving. This problem is commonly referred to as "the money shift". A number of stiffer aftermarket mounts are available at Bimmerworld.
-Differential clutch pack retaining ring bolts can loosen or back out, eventually resulting in rear end failure. If you hear a ticking noise in the rear, have the final drive checked out.
-Some clutches shudder when 1st or 2nd gear is engaged while the car is hot, or has been driven in stop and go traffic for long periods. This is due to a non-asbestos lining on the clutch plate. BMW apparently has a new lining available; however some new owners continue to experience this shuddering.
-Flex discs (also known as Guibo couplings) can crack or shred prematurely. This coupling connects the driveline to the transmission. Characterized by a knocking under the tranny hump or a thunking noise under acceleration. Not overly difficult to replace.
Antilock Braking System:
-Faulty ABS pump motor relays manufactured prior to May €™96 can trigger the ABS warning light.
-On rare occasions, the ABS warning light may glow briefly after turning on electrical accessories. This is a sign of a hardware problem with the ABS control module, which will need replacing.
-ABS rear wheel speed sensors on €™92 E36€™s had poor solder connections. If the date code is 0801 (80th day of 1991) or older, they need to be replaced.
-On some €™93 318is and 325is, six bolts which fasten the bottom cover of the ABS hydraulic unit to its housing may not have been tightened properly during production. The proper torque is 15 Nm. If it€™s looser than that, the hydraulic unit is probably damaged and should be replaced.
Steering:
-Many E36's had the lower steering column replaced as a result of corrosion; there was a recall campaign for this.
-Power steering hose can leak. In worst cases, the condition eventually leads to hose failure, resulting in a loss of steering assist.
-Worn tie rod ends are often noticeable as a judder under braking. This is commonly mistaken for warped rotors as it has almost the same feel.
Suspension & Undercarriage:
-Rear shock mount failure is a very common problem, and can occur in as little as 20k miles. The symptoms begin with a dull clunking noise in the rear over bumps or rough roads, indicating that the shock piston rod has separated from the bushing mount. This can progress into metallic noises as the mount bolts shear off if not replaced in a timely fashion. The broken mounts eventually damage and tear the rear shock towers. Stronger E46 mounts along with Z3 reinforcement plates are recommended for replacement, and even better aftermarket parts are available from outfits such as Rogue Engineering and Ground Control.
-Weak front outer ball joints are typical on the E36. A common solution is to use stronger E30 control arms with ball joints preattached, simplifying the installation. All metal ball joints (Meyle) are another alternative, but at the cost of a slightly harsher ride.
-Rear inner control arm bushings are another weak spot, and should be upgraded to the tougher €™96 or newer replacements.
-Under (but not limited to) heavy racing or track conditions, the rear subframe bushing mounts can tear off the body, causing extensive damage. Though rare, this typically requires welding reinforcement plates to repair the body.
-Rear trailing arm bushings can wear in as little as 50k miles, although there is debate on whether this is a fault or regular maintenance issue. Symptoms of bad trailing arm bushings include side movement of the rear end under acceleration, general looseness of the rear over bumps, and abnormal tire wear. United Bimmer has a DIY for this item. In a handful of isolated cases, the threaded holes for the console's 3 mounting bolts fatigued, allowing the console portion of the arm to break away from the car body.
-Some E36€™s may experience unusual wear along the outer edge of the front tires. This is resolved by replacing the upper strut to hub mounting bolt with an €œE36 camber correction bolt€. It€™s smaller in diameter than the standard bolt, allowing for ½ degree of camber adjustment. However, the dealer may not know what you€™re referring to, as the documentation on this part (#07 11 99 00 58 7) is very sketchy. Internet rumor has it that there are some sort of legal implications to this issue???
Electrical / Electronics:
-DME compartment flooding is a common problem for model years up to €™94. Symptoms are hard starting or no start condition after heavy rain or a car wash. Insufficient drainage allows water to collect in the intake plenum cowl for the heating/AC, and overflows into the DME compartment. BMW issued a service bulletin with an easy fix for the situation.
-Earlier E36€™s had issues regarding defective ignition coils from Zundspule and Bemis. They were replaced with Bosch coils. If you still have the older brands installed, replace them right away. Cracked coils can seriously damage the ECU.
-Corrosion on electrical harnesses, particularly 2 and 3pin sensor wires, can result in erroneous readings and trigger warning lamps. Certain plug connections have a rectangular seal which comes off unnoticed, allowing debris to enter and raise the electrical resistance in the circuit, triggering a false warning. Often these problems are misdiagnosed. Some tin plated contacts have been replaced with gold by dealerships over the years to alleviate these issues. Problems include, but not limited to, oil level/pressure warning lamps, camshaft sensor, coolant level/temp sensors, incorrect fuel gauge & speedometer readings, and brake light warnings. Contact cleaner works well as a preventative measure.
-Voltage regulators typically fail on 318€™s fitted with Valeo alternators. The regulator can be replaced separately.
-Power windows sometimes behave erratically, moving up or down only in 1€ increments. This is attributed to a magnet on the motor shaft falling out of position. The magnet can be moved back into position to correct this problem.
-A failing comfort relay causes the windows and sunroof to stop working inexplicably.
-In rare instances, owners have reported major wire chafing in the trunk harness, causing interior and exterior lighting failures and numerous blown fuses. Visually inspect this harness from time to time to be on the safe side.
-E36's with M42 engine and manual transmissions were recalled by BMW North America for incorrect routing of the oxygen sensor wiring harness. The wire could stretch and break, disconnecting it from the DME, and triggering the check engine light.
-A capacitor failure in the climate control module prevents the blower from operating while the AC compressor is engaged. The lights on the control module will also dim or go out completely. Fortunately, someone has figured out how to fix this without buying a new module.
-Glass breakage sensors on stock alarms supplied by Alpine can false trigger at times when the interior cabin temperature is high.
-Radio problems have been reported, most regarding dimmed or no backlighting. This is a dealer fix, but a better alternative is to replace the radio altogether.
-On some E36€™s, most notably the €™95 M3, a faulty circuit in the safety relay can activate the hazard flashers and unlock the doors while going over bumps in the road.
-The heater element on heated seats often fails and needs replacement.
-Brake light switch failures are common, although there is debate on whether this is a quality control issue. Replacement is fairly easy.
Interior/Exterior Fit and Finish:
-Inadequate water drainage and/or rust proofing on some models causes rusting at the bottom of the front passenger side fender where it meets the door.
-Brake ducts on earlier models were poorly attached and can be dislodged or fall off. This also damages or breaks off the external temperature sensor, which is attached inside the duct.
-Early fog lamp lenses crack due to temperature related stresses, a warranty fix.
-Some dashboards bulge up at the center air vent. Inadequate adhesion causes delamination problems on door panels. Midrange and tweeter speaker trim cracks are also common.
-Glove boxes can sag over time, there is a fix for this problem.
-Rear door noises on €™96 and later saloons are attributed to the type of rubber used on the door trim seals.
-Sunroof and rear parcel shelf rattles are common. Replacing certain parts in the sunroof mechanism fixes the noise, and you can support the rear deck with some foam stuffing to eliminate the rattle.
-Plastic headlight covers dull or get foggy. A number of compounds and polishes have been known to yield good results, but ultimately they ought to be replaced with the European glass units.
And there you have it, probably the largest compilation of its kind on the net (I think). This took some time to do, as I tried to confirm the validity of information as much as I could through research. But by no means is it the €˜end all, be all€™ . . . Feel free to PM me to add to elaborate, make additions or corrections to my points if you've experienced or know something that has relevance, as I may leave certain things out if I'm not familiar with them or have no experience on. This list will change over time as new info gets added, and newly written DIY links or photos are integrated.
Unread 09-19-2005, 03:19 PM   #2
that's a great writeup, should definetely sticky this. I might have to drive up to your house sometime, so you can fix some of those problems my car has.
Unread 09-19-2005, 03:43 PM   #3
Thats alot of great info dude
DO u got anymore info on the fix? cause mine has dimmed backlighting once in a while and other time its fine.
Unread 09-19-2005, 04:47 PM   #4
That's amazing.
Awesome job man. Let's keep it around the forum for a few days to a week and let people make suggestions for improvements, then I'll convert it to HTML and add it to the knowledge base.
How about a pre-purchase checklist of things to look at (bullet points)?
Unread 09-19-2005, 05:03 PM   #5
Come up anytime for a visit, no guarantee I can fix your problems, ha ha. I don't have that much BMW experience, I just compiled this from a bunch of resources around the net.
This is the only existing info that I know of about the DIY fix, unfortunately you have to be a member of Boston BMWCCA to view it
http://www.boston-bmwcca.org/bimmer/2002/10/radio.asp
Ha ha- you know how long it took me to do this, somebody else can do that pre-purchase list
Unread 09-19-2005, 05:23 PM   #6
Storamin
Storamin's Avatar
Title: Road Kill
what about the rear trailing arm bushings? these can go as early as 50k miles.
Unread 09-19-2005, 05:37 PM   #7
^^^I thought about this too, since I just replaced mine back in June, but I'm not certain it's a design/manufacturing flaw. If anyone else knows for sure that it's a defect to wear out at 50k, chime in.
Unread 09-19-2005, 11:17 PM   #8
well ill still come up I guess, need to practice driving long distances heh. Any idea how far your house is from Northern Delaware? I live about 30 mins from philadelphia.
Unread 09-20-2005, 12:22 AM   #9
Storamin
Storamin's Avatar
Title: Road Kill
bmw will not admit it is a defect, but many people believe it is. they disagree that pretty much anything bushing related is a defect, stating it as a 'wear and tear' item.
Unread 09-20-2005, 12:27 AM   #10
its funny, when i was replacing the engine on the e36, i used the old engine's thermostat housing and waterpump b/c they were metal
Unread 09-20-2005, 01:03 AM   #11
Spieluhr
Title: ///M Driven
that is a great write up man. If i think of anything I will chime in.
Unread 09-20-2005, 02:35 AM   #12
zeaq328i
zeaq328i's Avatar
Title: BMW 328i
Rate My Car: 314 / 340
Your Ride: BMW 328i and Dad's S320*NowLondon underground Tube*
Send a message via AIM to zeaq328i Send a message via MSN to zeaq328i
Wow.I'll read later
.BMW 328
Unread 09-20-2005, 03:05 AM   #13
RealBmw 02
Title: GRIP > DRIFT
Rate My Car: 76 / 340
Send a message via AIM to RealBmw 02
man that is a great writeup... even tho I don't have an E36 and it doesn't pertain to me, I am sure many people will really find this helpful
1970 BMW 2002
Driven by skill, not money
"Real BMW's have round tail lights"
Unread 09-20-2005, 05:09 AM   #14
Yes, I came across a lot of that sentiment while doing the research. Their standpoint seems to be the same regarding other things too, like the climate control failure and window motor failure. I wouldn't single them out though; other car manufacturers have the same type of issues and policies.
But I think if the other 'questionable' stuff made the list, I guess the RTAB's should too. Especially after what I uncovered last night as a result of your post . . apparently there have been a few extreme cases where the bolt holes for the trailing arm console deform and tear apart. This is the 3 mounting bolt holes where the trailing arm attaches to the car body, that alows for toe adjustment.
Anyhow, I'll wait for a few more suggestions for changes, and I'll add it in
(Edit): Done
Well, Philly is about 1-1/2 to 2hrs from me, depending on traffic of course. But it's a straight shoot up the NJ Turnpike to exit 14c. Yea, come up if you got nuthin to do, we'll head in to Hoboken for grub and drinks
Unread 09-20-2005, 02:41 PM   #15
umm im 17 so make sure it's a bar that is lenient
We should get a meet going somewhere not too far from both of us though. Maybe in the philly area?
Common BMW problems FAQ Dudesky Site Feedback 2 09-07-2005 04:30 PM
