Unread 01-02-2012, 11:42 AM   #1
techmike
Your Ride: 2005 325ci
Brake kits
I have a 2005 325Ci and I'm going to need brakes soon and I have a coupe of questions. 1 if the rotors aren't damaged do they need to be replaced when you replace the pads? 2 Can original rotor be cut or resurfaced? I get e-mails from Auto Parts Warhouse and they have crossed drilled brake kits (rotors, pads, senors) all four wheels for $320 has anyone tried them? Powerstop K872 Brake Disc and Pad Kit- Cross-drilled and slotted.
Unread 01-02-2012, 12:13 PM   #2
Hi techmike. When you replace your pads you don't need to replace your rotors. Your rotors have a minimum safe thickness at which they are no longer capable of properly stopping the car. Rotors can be resurfaced until you get close to this minimum thickness. Factory rotors can be drilled or slotted but they weren't designed for that.
ECS Tuning has an excellent selection of brake parts. Including Hawx brake pads. I have heard good things about the Hawx pads from fellow BMW owners. Definitely worth looking into IMO. The prices seem reasonable and they have packages available as well.
Unread 03-14-2012, 08:08 AM   #3
janepaul
Your Ride: 2009 3 series
read the stuff you posted it woulde help me a lot thank you..
DIY: E39/E36 Brake Pad Replacement mullethunter3 BMW OEM Parts Department DIY's & FAQ's 11 12-20-2014 07:21 AM
633CSi brake booster kits & CSi & CSi A slyhog-22056 6-Series (E3, E24, E63, E64) 5 10-26-2012 01:00 PM
***LIGHTING forum BI MONTHLY special, SLIM HID kits ONLY $95*** habbie Lighting 4 05-15-2009 01:51 AM
