Unread 12-27-2011, 11:38 PM   #1
MaximunR
Your Ride: Z3 1998
right turn light not working
Front and rear lights work also left turn lights. right turn lights are not working and is not displayed on the cluster. All lights are ok, what can i do?
Unread 12-28-2011, 10:47 AM   #2
What year and model is the car? In the taillights the bulb ha a socket that it sits into which then connects into the taillight housing. Their should be a plastic cover that comes off easily in the trunk for each of the tail lights. Remove it and then you will see the black sockets protruding out from the light assembly. Turn them a quarter turn to remove them. Inspect the bulb and see of it is loose. Inspect the socket and see if it is loose in the assembly. I had to replace two of them for my brake lights because they were loose. They were only like $10-15 at the dealership.
For my 1998 328i it's part # 63-21-1-387-365 E36 Lamp Socket.
Unread 12-31-2011, 05:54 PM   #3
Another possibility is some models have separate fuses for each set/side signals. Check those too
Unread 08-04-2012, 11:34 PM   #4
gc325is
Your Ride: 325 1995
Right turn working
I had a nonfunctional right turn signal, I could get it working if i wiggled the stalk, but it would fail again. Pulled apart the steering wheel covers and was going to remove the switch but it is hard wired to some other controls. So I just sprayed WD 40 to clean the contacts. Works great now.
7 Series E38 - audio working/ not working - airbag light flickering... Durny 7 Series (E23, E32, E38, E65, E66) 0 06-06-2011 05:29 AM
BMW 2011 TELE ATLAS Navigation DVD w/ Red Light Camera & Police Speed Traps Review delmarco Car Audio and Electronics 1 01-16-2011 03:03 PM
Need Help! Turn Signal turned off but light on dash kept blinking... Beamer T E46 2 06-08-2010 07:49 PM
Random bulbs stop working after taking trunk light out chaz110789 Lighting 0 04-11-2009 02:09 AM
Someone Paleeeease turn that light off.... Timboy E46 11 02-24-2006 04:15 PM
