Unread 09-14-2005, 02:56 AM   #1
delmarco
delmarco's Avatar
Rate My Car: 227 / 340
I think my battery done for. What should I replace it with?
or what is a good brand Battery for a bmw E36?
I'm going to the local Sears here for a $12 diagnosis and I think I may have to get Diehard... cause that is discounted if the diagnosis tells me I need a new battery...
help...
Unread 09-14-2005, 09:22 AM   #2
Storamin
Storamin's Avatar
Title: Road Kill
go to a local autozone, they test batteries for free. don't pay 12 dollars to have it tested.
Unread 09-14-2005, 11:27 AM   #3
BMWLotAttendant
Title: I Drive EVERYTHING
Your Ride: 1997 Camry CE
You should replace it with another battery.
Unread 09-14-2005, 11:31 AM   #4
zeaq328i
zeaq328i's Avatar
Title: BMW 328i
Rate My Car: 314 / 340
Your Ride: BMW 328i and Dad's S320*NowLondon underground Tube*
Send a message via AIM to zeaq328i Send a message via MSN to zeaq328i
Del,
Are u in NY or in your new town?
.BMW 328
Unread 09-14-2005, 11:40 AM   #5
Storamin
Storamin's Avatar
Title: Road Kill
damn and i thought a toaster would work!!
Unread 09-14-2005, 11:52 AM   #6
I just got my battery replaced, I think the guy gave me an interstate one or something. I think it was something crazy like $100, but he probably charged to put it in which is gay... Even though he drilled some hole that was supposed to be there.
Unread 09-14-2005, 12:03 PM   #7
get the most powerfull battery you can fit in there. Cause if u plan on putting in stereo upgrades like subs and stuff itll pay off big. the more power the more accesories u cna have or longer u can have em on
Unread 09-14-2005, 12:27 PM   #8
delmarco
delmarco's Avatar
so batteries have power rated other than volatge ratings?
I'll look into to it...it seems that brand is not much of an object...
I was thinking that one brand may be the best...
I'm in Tallahassee Zeaq...and Sears is the only place I've found so far. After classes I'll probably drive around. Target at the Mall also sells batteries.
Unread 09-14-2005, 12:52 PM   #9
I made the mistake of replacing mine with an OEM battery from the stealership.
Unread 09-14-2005, 01:51 PM   #10
zeaq328i
zeaq328i's Avatar
Title: BMW 328i
Why?Mine is the OEM battery..
.BMW 328
Unread 09-14-2005, 03:36 PM   #11
donald1476
Title: President
Rate My Car: 109 / 340
Send a message via AIM to donald1476
I replaced with OEM too.
Unread 09-14-2005, 03:50 PM   #12
catalyst
Rate My Car: 195 / 340
Optima batteries are the best batteries on the market right now.. a very good way to shed some weight too - theyre much lighter than stock.
theyll set you back 100-140 though.
Unread 09-14-2005, 04:01 PM   #13
donald1476
Title: President
Optima batteries....so hot right now.
Unread 09-14-2005, 07:52 PM   #14
Make sure the vent tube is properly reconnected & routed when you get the battery replaced.
Unread 09-14-2005, 08:02 PM   #15
catalyst
oh yeas
How to replace 540i front brake pads and rotors Cambridge E12, E28, E34, E39, E60 1 03-21-2006 09:56 AM
Replace your Microfilter! Spieluhr E36 16 12-23-2005 07:09 PM
Do I Need to Replace DME Chip ?? singring E36 1 12-17-2005 09:54 AM
How to replace a radiator in a 540i Cambridge E12, E28, E34, E39, E60 1 12-02-2005 06:58 PM
My battery is dead Rooz E36 24 05-24-2005 11:30 PM
