Unread 04-23-2005, 06:25 PM   #1
B3M2W5i
B3M2W5i's Avatar
How To Remove/Replace emblem
basically you should do it step by step in this order:
1. get your embelem(s) and grommets
2. to remove emblem slip something like an old id card in between the emblem and body then put a cloth under it just to make sure u dont scratch the paint
3. then stick a flathead screwdriver in to pop it off be sure to slide it around to make it stick out then pull it off <if you dont care about the emblem>
4. you'll then notice that the grommets stayed either on the emblem or on the hood/trunk so to pull it off the hood/trunk just get a pair of needlenose pliers and pluck it off
5. then clean the area
6. push the new grommets in place
7. push the new emblem in and there you go
almost forgot, i love my girlfriend
Cashmere Beige Metallic
Unread 04-24-2005, 09:50 AM   #2
Thanks for the DIY, I need to replace my front roundel.
Unread 04-26-2005, 01:10 AM   #3
bostongreen18
replacing your roundels is one of the best things you can do to make your car look new again. its also incredibly easy.
Unread 04-28-2005, 03:27 PM   #4
brien4787
Title: DelTaco
Your Ride: e36
i do it this way...
1. pop the hood
2. move how ever much foam stuff on the other side of your hood out of your way
3. you will see the two silver things(back of the roundel) sticking threw the 2 holes.. just push on them and out comes the roundel.
4. close your hood (1st make sure you put the foam stuff in place that you moved out of the way) and push the new roundel in.
weeee
Unread 04-30-2005, 11:07 AM   #5
528man
good info
1997 528i
Unread 04-30-2005, 11:53 AM   #6
Antiburn
Antiburn's Avatar
Rate My Car: 193 / 340
Get a flathead pocket screwdriver. Real small and skinny. Put down a paper towal or napkin and slip it under and pry up. You dont even need to replace the groments but if you have them why not. Then just beat the new emblim on with your palm. It takes about 2 minuets.
Unread 07-13-2005, 09:27 PM   #7
brien4787
Title: DelTaco
Your Ride: e36
my way is the safe way(and seemed to be easier)
Unread 07-14-2005, 11:45 PM   #8
B3M2W5i
B3M2W5i's Avatar
thats cool thats why this thread is here to help people out
USA to change it's emblem. Torque Comedy Collection
52 09-24-2005 03:45 AM
