Unread 08-26-2005, 08:31 PM   #1
defkon99
defkon99's Avatar
Rate My Car: 50 / 340
Your Ride: 1993 E36
Angry water leak damn another problem!!!
ok so i get in my car to go to Autoparts to buy a Cabin Filter ?
(driving normal 35mph ) i get to the shop. i park and shut off the ignition, for about 5 seconds i sit in there listening to a sizzing sound and water dripi get out and take a look under the car, and wham! freakin juicing out bunch of water with sizzle sound, im like WTF!
so i figure its just well i dont know, so i go in come out with my filter i just purchased( 5 min later).
pop the hood then i hear no sound or see no drips from under the car. im like whew, so just to check i open the radiator coolant, its freakin low, i go buy some coolant pour that in, it took 1/4 of the gallon. So i start my car again and i see little drips. i get back on the road driving home and i start seeing the temp gauge climbing. Argh !
So i get in the parking lot open the hood and again i hear the sizzle sound and now i see steam but its not coming from the radiator its coming from the back by the firewall bottom of engine,
anyone got an idea on wtf just happened!
Unread 08-26-2005, 08:46 PM   #2
Which side? Auto trans, or manual?
Unread 08-26-2005, 08:55 PM   #3
defkon99
defkon99's Avatar
Your Ride: 1993 E36
auto
hear the noise coming from the back by the firewall ( side of brake booster, intake etc.)
and some steam from the other side back of engine.
Unread 08-26-2005, 08:59 PM   #4
That's what I was thinking. Could be the 4-way hose that goes to the block, heater outlet, and expansion tank. If so, it's about 60-65 bucks if you plan to replace it yourself.
Unread 08-26-2005, 09:01 PM   #5
defkon99
defkon99's Avatar
Your Ride: 1993 E36
shit shit shit! ok umm damn i dont know where thats at !! damn umm got a link or photo oor siy oh man ( i just started a new job too and this happens damnit!)
Unread 08-26-2005, 09:04 PM   #6
yeah there are a few hoses back there, check your hose to the heater core.. actually try turning on your heater full blast and see if it is hot air, if it isnt either it is that hose or you have air in your system, most likely one, or maybe even both
btw after you replace that hose if you do, make sure you bleed your radiator
Unread 08-26-2005, 09:04 PM   #7
B3M2W5i
B3M2W5i's Avatar
take it to a mechanic man before anything else goes wrong
Cashmere Beige Metallic
Unread 08-26-2005, 09:14 PM   #8
Here's what it looks like:
Unread 08-26-2005, 09:15 PM   #9
defkon99
defkon99's Avatar
Your Ride: 1993 E36
dang weird , ! ok is there a Pn or a name for it , gotta see if autozone of some fools has it.
Unread 08-26-2005, 09:20 PM   #10
That's what it's called, a 4-way hose, and it's kinda specific to BMW, I doubt Autozone will have it in stock. Probably a special order item. But first make sure that's what your problem is.
Unread 08-26-2005, 09:24 PM   #11
defkon99
defkon99's Avatar
Your Ride: 1993 E36
Oh GOD i think im gonna DIE! where to start!!!
possibly change the water pump? cheack oh man i wish it was daylight!@
Unread 08-26-2005, 10:18 PM   #12
waterpump? you said it was leaking from the back, right?
Unread 08-26-2005, 10:36 PM   #13
defkon99
defkon99's Avatar
Your Ride: 1993 E36
yea leakin from the back ( i talked to my dad ( worked on cars for over 20 yrs) he said i may be just a hose , check the heater core ) but man who knows why that temp needle was climbing on my way back home maybe the water pump or thermostat both may be fuct.
Unread 08-26-2005, 10:44 PM   #14
yes, the temperature needle was climbing probably because you have air in your system, thats why i said turn on the heater and see if it has hot air, and if it doesnt then you need to bleed your system
Unread 08-26-2005, 11:08 PM   #15
defkon99
defkon99's Avatar
Your Ride: 1993 E36
ok will do also i have a pik here and would like to knoiw what u guys think about these 2 a hose would go on that area and maybe possibly would it be a freeze plug.
thx 4 yur input
water pump cabrit E36 2 02-28-2006 05:10 PM
problem with cams e30boarder E21, E30 3 09-06-2005 09:44 PM
