Unread 04-22-2005, 06:11 PM   #1
xxxbimmer
Rate My Car: 48 / 340
Unhappy No Abs
m getting the error code 132 (made my abs light come on)
brake censor or something?
ne 1 know where i can get the part...and if i can do it myself
Unread 04-22-2005, 11:13 PM   #2
bitcore
bitcore's Avatar
Looks like an abs sensor is malfunctioning or your ABS relay is shot. You may want to wait for another reply for more information. I'm fairly inebriated at the momnt but the information I gave is accurite... yet vauge lol.
Unread 04-24-2005, 04:56 AM   #3
xxxbimmer
sounds like fun
Unread 04-24-2005, 03:27 PM   #4
thekid
Send a message via AIM to thekid
That sounds about right. Only problem is you don't really know which one(s) is failing. When did you get your brake pads chagned last? Did you replace the senors at the same time? If so I would check the relay, if not get four sensors and go ahead and change them all, unless you have a way to get all four wheels up off the ground. In which case just change them out until you figure out which one(s) is out. Even if only one is out, these things are cheap and good to have around because most of the ABS lights are from brake sensors. If this doesn't work try the relay. I don't have any diagrams to show you how to do it, but www.pelicanparts.com will most likely have a DIY or a parts diagram that would show you where the sensor is. From there grab a jackstand and your wrenches and find it.
Unread 04-25-2005, 02:48 AM   #5
xxxbimmer
i had the sensors replaced.........
the bmw place said it was some sensor that measures how far the pedal is being pushed.......and its near the brake booster........
ABS help jybute BMW OEM Parts Department DIY's & FAQ's 8 02-05-2006 12:12 PM
2 Quick and General ABS questions... delmarco E36 4 08-06-2005 03:34 PM
HELP! Dealership wants $450 for ABS left wheel sensor!!! delmarco E36 5 07-17-2005 02:03 AM
Car Done! ABS code read, Brakes/Rotors checked out for $25! delmarco E36 9 07-11-2005 04:24 PM
Back to the dealership! yearly inspection, ABS light, new pads&rotors$$$$ delmarco E36 14 07-07-2005 09:42 AM
