Unread 09-26-2011, 11:13 AM   #1
lcfc123
Your Ride: 2000 325i
help- overheating problem
all of a sudden my 325i starts to overheat, i lift bonnet and there is a hissing noise coming from the water cap, i add water and it starts to spit it out as it bubbles, what could this be???????
Unread 09-26-2011, 12:44 PM   #2
Low coolant issue, leak somewhere in the system, air bubble in the system, bad radiator cap, failing water pump or clogged radiator causing an overheat, failing cooling fans causing an overheat (that's the basic stuff). Or more seriously a warped head/failed head gasket (which is less likely but there's not enough info to go off of in your question).
Unread 09-27-2011, 09:28 AM   #3
Never add water until the car cools down.
I would remove the bleeder screw next to the fill cap, fill it up until liquid comes out the bleed screw, (key on, heater full hot setting) and then watch for leaks over the next few days. On an 11 year old car, the first two suspects would be the expansion reservoir (where you add the water) may be brittle and cracked, or the O-ring on the water temperature sensor on the lower radiator hose. That will leak only when the car is hot and there is pressure.
If you have over 150k miles, the water pump may be leaking. That is tough to see until you get all the stuff removed from the front of the engine. By the time you get that much work done, you will want to replace the water pump as preventative maintenance even if it turns out to be still OK.
e90 320i idle problem vibrating bmwdrivingmemad E90 1 07-17-2011 02:39 PM
Bmw Overheating Problem -please Help souljahslim E36 7 04-25-2011 05:45 PM
E36 328i 1998 Mystery Overheating.. bmw328i98 E36 7 12-21-2010 12:29 PM
325 brake light problem fgmx Lighting 2 02-01-2008 02:52 PM
