Unread 09-11-2011, 03:05 PM   #1
kidneyman
Your Ride: z4 2.5 auto
Question water leaking from around jacking point on sub frame
Hi, can anyone tell me why I get water inside the subframe, which I can only remove by 'moving' jacking point so it leaks out. Car is 2004 z4 2.5 auto
Unread 01-03-2012, 01:46 PM   #2
robertshort
Your Ride: Z4 2004
I had the same problem with my 2004 Z4. The Z4 has drain holes to get rid of that water just behind the door where the top pevits. You need to take a long rod and clean the holes out on each side and the water will drain. And when you get the water running, use a water hose with some pressure and spray all around where the top is assembled to the rear of the car. Keep this area clean.
Why coolant is leaking 325iZYX Introductions and Greetings 0 07-13-2011 01:39 AM
Detailing techniques and products... ivopivo Detailing and Cleaning 2 09-15-2009 01:51 PM
Advice on new DIY project... E30 M10 water pump mullethunter3 E36 16 12-13-2006 10:29 PM
Water vs. Coke brien4787 United Off Topic  **FOR MEMBERS ONLY** 1 03-25-2006 01:07 AM
