Unread 08-12-2005, 10:55 PM   #1
billycuth
billycuth's Avatar
Your Ride: 2004 Acura TL
New Exhaust DIY
Well, I know this is simple, but as with any mod, you run into a little modifying here and there, or you are left to come up with some sort of gameplan. Let me preface this DIY with one simple notion. Make sure your car is not going to move while it is off the gound. I used ramps and jack stands for this project.
the old exhaust (different views)
(See Haile, I have the dual cats.... I am surprised your car didn't, or Komodo's)
Here is where the game plan comes into effect. The new Stromung came with no installation instructions, which often guide you as to what you should do and when. Well, I started by removing the rear brackets first. Do NOT do that. Makes the other 4 bolts VERY difficult to get back on! I ended up re-tightening the rear brackets until I got the other four bolts off.
Here are the bolts you need to remove...
rear bracket (remove last!)
four bolts attaching the exhaust to the catalytic converters...
After fully removing all bolts, (only need to loosen the rear brackets, not completely remove - which helps installing the new exhaust quickly) you should be able to wiggle the exhaust free and end up with a nice empty space like this....
Unread 08-12-2005, 11:04 PM   #2
billycuth
billycuth's Avatar
Next, install the new exhaust. I chose to cut the box out around the exhaust so that I could slide it under the car without scratching it. If you leave the rear brackets installed, you won't need any tools yet. The reinstall went so fast, I didn't have time for new pics...
Slide the 2 pipes into the receiving end of the catalytic converters first. One pipe has an extension that allows you to slip the new exhaust pipe over it to hold it in place (before re-securing with new bolts.
Now slip the 2 muffler ties in with the existing rear brackets. Then tighten them. Now, finish by securing the 4 bolts at the other end...
You're done! Here is some comparison pics before the install, and some after install pics... I need new hardware for my setup, but it will have to wait till tomorrow because it is midnight now!
now that you see how easy it is, save yourself the money and BUY ONE!!! I recommend understeer.com. Chris is a great guy!
Unread 08-12-2005, 11:06 PM   #3
billycuth
billycuth's Avatar
anyone know what this is?
and what I am supposed to do with the little cord thingy that is coming out of it?
Unread 08-12-2005, 11:10 PM   #4
Great pics. Moving to the DIY section, thanks.
Unread 08-12-2005, 11:11 PM   #5
billycuth
billycuth's Avatar
komodo, did you get your vids or sound clips yet?
Unread 08-12-2005, 11:12 PM   #6
Not yet, hehe. <3
Unread 08-12-2005, 11:16 PM   #7
Nice man, very good DIY. And i think that last pic has something to do with the fuel system,i dunno exactly what. but it looks like it connects to the gas tank from what i can see. Someone correct me if wrong
Unread 08-12-2005, 11:17 PM   #8
I forget where the hose goes... I remember Karl (zeit00 on here) once telling me. With most exhausts you just have to plug it and tuck it away somewhere or it'll cause a vacuum leak. A golf tee works very well for this.
Unread 08-12-2005, 11:26 PM   #9
billycuth
billycuth's Avatar
if you guys could find out for sure, I'd really appreciate it... Haile would probably know, since he installed the same exhaust....
Thanks for the positive comments!
Unread 08-13-2005, 05:59 AM   #10
Excellent DIY!
Yea, it looks simple, but you probably saved the next guy a whole lot of time and sweat after you realized which end should be unbolted first. It's all the little things that make the difference
Unread 08-13-2005, 11:27 AM   #11
Whoa, I never knew that about the M52 exhaust. That's awesome. I'm surprised they haven't made an aftermarket exhaust like that.... up to 5500 rpms it's going the long way, and after that it opens up to a huge uuc muffler or something to roar...
Unread 08-13-2005, 12:23 PM   #12
jrhaile
Rate My Car: 114 / 340
It attatches under your bumper right near your gas tank. It's not important. I would just tie it up and zip tie it out of the way haha...
Unread 08-16-2005, 10:28 PM   #13
Great DIY! I can't decide between the stromung and an AA gen 3
Eisenmann Exhaust GB 8%-10% off Rooz Bmw Cars For Sale/Wanted 20 08-23-2005 02:12 PM
So me and Komodo were testing out his exhaust ChrisWorrell Kill Stories 10 07-14-2005 12:04 AM
UUC Exhaust bmw4life E36 26 04-26-2005 09:43 PM
