Go Back   United Bimmer Community - BMW Forum > UnitedBimmer-General BMW Topics > Introductions and Greetings
Introductions and Greetings Sponsored by: match.com
New to the site? introduce yourself here and tell us a little about you and your sled. This is the "Hi, my name is and i drive" forum.
Unread 07-13-2011, 01:39 AM   #1
325iZYX
Your Ride: 325i
Red face Why coolant is leaking
Hi,
I have 2001 325i, changed the water pump and thermostat last year. A week ago expansion tank was leaking and notice a crack. Replace the expansion tank and coolant. I fill with 50/50 mix (BMW coolant and Distilled water) and when engine was cool opened the expansion tank cap and checked coolant level 3 times after running the engine for 10 minutes while revved the engine with heat on hi. Later, I have run the engine for 30 minutes and water temperature position is at 12 o'clock. I went for 15 minutesí drive the water temperature position was still at 12 o'clock, however coolant sensor came on indicating I was low on coolant. I notice it was leaking coolant on the same side as expansion tank. I double checked everything and did not see any cracks and all caps and blue screws were tight. Any idea why coolant is leaking? Thank You All.
MY 03 325i coolant is leaking & overheating.. PLZZ HELP kurtk E46 4 09-16-2011 08:53 AM
Coolant leaking above tranny!! HELP!! JBM BMW E36 E36 21 01-15-2010 07:52 PM
Coolant leaking E39 528i Sport Shy Shy E12, E28, E34, E39, E60 9 01-06-2009 12:54 PM
Coolant Leak, Fuck (long post) bartb E12, E28, E34, E39, E60 0 03-22-2008 12:25 AM
Overflow Coolant cap on E36 Mercenary(FH) E36 10 04-06-2007 10:31 AM
