Unread 08-01-2005, 05:53 PM   #1
Cheapest water pump price?
Changing out my water pump, and $58 at AutohauzAz is the cheapest I've seen . . anyone found a cheaper price? I thought I saw it for like $46 someplace, but I can't remember where.
Unread 08-01-2005, 06:17 PM   #2
jrhaile
Rate My Car: 114 / 340
Make sure you get a metal based one.. don't just get an oem plastic one again... go to understeer.com and order one.
Unread 08-01-2005, 06:21 PM   #3
defkon99
defkon99's Avatar
Rate My Car: 50 / 340
Your Ride: 1993 E36
Thumbs up
Link hey i found this one shippping from Ohio $45.00 + 7.50 S/h = $52.50
BRAND NEW Meyle Water Pump that fits many late model BMW's. This is a premium water pump with a Metal Impeller. The earlier plastic impeller water pumps have a high failure rate. This Pump Also fits E36 M3's to replace the plastic style pump.
Meyle Products
Meyle Products is a devision of Wulf Gaertner Auoparts which was founded in Germany in 1958. Meyle offers high quality products for European cars and trucks. The range of products is constantly being expanded.
Unread 08-01-2005, 08:45 PM   #4
i have a question, what years were the impellers made of plastic? what year were they replaced with the metal ones (if they were factory replaced)?
Cause ive heard alot about it and all but i just wanna know if my '98 328i would still have the plastic one.
Unread 08-01-2005, 09:06 PM   #5
Beater_Bimmer
Beater_Bimmer's Avatar
Your Ride: 1993 BMW 325i
Send a message via AIM to Beater_Bimmer
yea and how do i know if i have a plastic one? i heard something about it being orange?
Unread 08-01-2005, 11:10 PM   #6
From what I've heard, the plastic (orange) impellers were used up till early '97. But there's no way to tell for sure without removing the pump. If you're not sure, don't play Russian Roulette with it, just change it out for peace of mind.
Mine was already changed out and has about 30k on a metal impeller, but I figure I should replace it again while I have everything apart . . . I'll be flushing the coolant, doing the fan delete mod, switching to an aluminum thermostat housing, and replacing the upper & lower radiator hoses. After this, I should be good to go for a while.
[Edit]: Ahhh, found one on eBay for $41
Unread 08-02-2005, 12:14 PM   #7
K thanks, good to know. When i do the fan delete mod (when i get more money) ill replace the impeller and do some of the stuff you are. probably smart in the long run
Unread 08-02-2005, 12:46 PM   #8
E36Bimmer
Rate My Car: 142 / 340
both the metal and plastic impellar pumps can fail.. this seems to be one of the parts BMW can't get right. Nice cheap fix tho
Water in tail lights? witeshark BMW OEM Parts Department DIY's & FAQ's 8 01-12-2013 12:30 AM
water pump cabrit E36 2 02-28-2006 05:10 PM
need air pump to pass emissions? Spieluhr E36 2 09-06-2005 06:10 PM
