Unread 06-28-2011, 01:56 PM   #1
jkw333
Your Ride: 1995 325i convertable
Angry Can't open the trunk
I have a 1995 325i convertible that will not let me in the trunk. I believe the button works, but the catch will not release to open the trunk lid. Anyone have any ideas?
jkw333
Unread 06-30-2011, 08:43 AM   #2
There is a link from the button mechanism down to the latch that has plastic clips on either end. When the plastic clip and the hole wear a bit, the clip pops out of its hole and the link just dangles.
On e36 cars with fold down rear seats, this is no problem. You just crawl in the trunk and snap up the trunk lid liner and reach in and pop the trunk. Then replace the plastic clips on the ends of the link. My daughter did this on her '97 last year.
In your case, you will likely have to find a round rubber sheet metal plug at least a half inch in diameter. Then remove your license plate and drill a hole that fits your plug near the center of the license plate. Then reach in with a hook and release the trunk lid. Then repair. I have not done this, but it is the only solution I can think of.
Unread 07-12-2011, 08:24 AM   #3
Grouchoman
Grouchoman's Avatar
Your Ride: 1995 325i Convertible
Put away the drill
God no...don't drill a thing. On a convertible, remove the back seat and then the screws that hold that ski holder thing (useless) that is normally covered by the middle arm rest. get yourself a good flashlight and something long and steady. When mine did this, i had to reach in with arms and tools to get to the latch, which then can be popped (provided you have 'unlocked" with key....by hitting the side of the latch upward.
It is tricky and hard to get at if you are any kind of sizeable person. I ended up using a golf iron to get the extension to the part once i got down and understood the mechanism. You catch that "connecting rod" and pop it. Look at the realoem diagram of the parts and note the connecting rod. If you can get your arms in and use channellocks or pliers then great....but if not, then use a long stick of wood or metal (hence the club) and pop it that way. Then use the tips above to replace the plastic nut connectors. Rarely is the lock smoked...it is almost always the failure of those plastic parts.
Scott B
Grouchoman
Grouchoman
"Remember men, we're fighting for this woman's honour; which is probably more than she ever did. "
Unread 07-23-2011, 11:44 PM   #4
AtomE36
Your Ride: 96 328i Cabrio
E36 stuck trunk
Grouchoman,
does it matter which side of the latch that you hit? does this action alone get the trunk open?
Thanks,
Lou
1996 328is Trunk lock will not open foaxaca E36 3 06-06-2011 10:38 PM
04 745 E66/65 trunk electricaly doesn't open x5bimmers 7 Series (E23, E32, E38, E65, E66) 0 08-08-2010 04:57 PM
Fixed!!! Trunk wont open 318i johnjackson80 E36 1 01-02-2010 03:36 AM
HELP! trunk wont open on 318i johnjackson80 E36 4 12-24-2009 01:05 PM
Trunk Will not Open, any ideas nick_318is E21, E30 6 08-14-2005 01:21 PM
