Unread 07-28-2005, 02:07 PM   #1
ivopivo
ivopivo's Avatar
Rate My Car: 140 / 340
Your Ride: 1993 BMW 325i and 2009 Yamaha R6s
Send a message via AIM to ivopivo Send a message via Yahoo to ivopivo
stock alarm and angel eyes...
is it possible to wire the angel eyes to blink with the factory alarm ?? once for locking and twice for unlocking as the alarm sounds ?? i don't know if it's possible with the stock alarm or if you need aftermarket alarm ? thanks
-Ivan
LUSTR Auto Detail
"Always start with the least aggressive method!"
Unread 07-28-2005, 08:30 PM   #2
I haven't bought my angel eyes yet, but as far as I know, they use ballasts. That means they have to charge, and don't turn on instantaneously. I think there's a slight delay, so I'm not sure you could 'pulse' them with the alarm. Or maybe I'm wrong.
What you can do, and what I'm gonna do, is wire them up so they turn on using an accessory button on the alarm remote, completely independent of the parking light circuit. It'll be a few weeks yet, but I'll post a DIY once I get them.
Unread 07-28-2005, 09:19 PM   #3
jrhaile
Rate My Car: 114 / 340
Unread 07-28-2005, 10:34 PM   #4
I stand corrected . . that is freaken cool.
Unread 07-29-2005, 01:13 AM   #5
ivopivo
ivopivo's Avatar
mine didn't have a ballast, they just need to hook up to a power wire and they're on when you turn that power wire on, or give it power whatever the terminology is.
-Ivan
LUSTR Auto Detail
Unread 07-29-2005, 01:22 AM   #6
ivopivo
ivopivo's Avatar
Originally Posted by jrhaile
it looks like he has the angel eyes set up as DRLs ??
-Ivan
LUSTR Auto Detail
Unread 07-29-2005, 01:47 AM   #7
defkon99
defkon99's Avatar
Rate My Car: 50 / 340
Your Ride: 1993 E36
so jrhaile did u ever fix that noise? sounds like the belt, does try running some bar soap under the belts see if that fix it.
Unread 07-29-2005, 06:24 PM   #8
sounds like a fan clutch issue, actually, after looking at that vid twice:
See when I did my underdrive pulleys, my belt tensioner snapped on me (Almost blew up in my face), and I replaced, and I had somewhat of a similar sound to yours but less noticeable, and after that it went away. So like I said it could either be a fan clutch issue or a belt tensioner.
Unread 08-06-2005, 04:30 PM   #9
yeah James and I were wondering, we both have same sound.
Unread 08-15-2005, 03:31 PM   #10
bimmer95
Title: village fool
Rate My Car: 30 / 340
The first problem is that the stock BMW alarm doesn't flash the corner lights, it only chirps the alarm. If you modify the alarm to flash the parking lights, then you're set, that is if your halos are wired to the parking lights. On and aftermarket alarm you may still have problems if your alarm is wired to flash the turn signals instead of the parking lights.
A simple trick would be to wire your 12v+ siren output, by way of a diode, to your running light wiring. That way your running lights and halos would flash when the alarm chirps, but would light solid when the alarm is going off. Not a great solution either, but it's an option.
Unread 08-15-2005, 03:36 PM   #11
billycuth
billycuth's Avatar
Your Ride: 2004 Acura TL
haile - tell that man to get his alignment checked out!
I am worth $2,022,318 on HumanForSale.com
Unread 08-15-2005, 03:51 PM   #12
yea haile that noise is your belt tensioner, i had a similar noise, b/c there is a little tiny plastic piece that prevetns water from coming in and i was too lazy to replace it so i would just spray some WD40 in there (while the car was on so it would circulate, and yes splash a little) and it worked
