Unread 05-26-2011, 10:30 PM   #1
jbv1
Your Ride: 2004 330xi
Passenger side AC hotter than drivers side
Very hot outside here in san antonio, when a/c is on the drivers side a/c gets ice cold, but the passenger side is hot. heres the kicker, if i park in shade all day both sides cool off, but direct sunlight all day at work and the pass. air takes for ever to cool off a little bit. i dont get it. i dont have dual climate control its a 2004 330xi????????????
Unread 05-27-2011, 11:05 PM   #2
jbv1
still no suggestions.....wow...., not like powertstoke.org everyone had some idea???
Unread 06-28-2011, 09:58 AM   #3
The refrigerant goes through the evaporator sideways. The first hint that you are low on refrigerant is that the downstream side of the evaporator will not be as cold as the the upstream side. These units are VERY sensitive to the amount of refrigerant they contain, so it may take only a fraction of a pound to get the system back in order.
PICTORIAL DIY: E46 AC System Troubleshoot and Recharge delmarco E46 4 08-17-2011 12:21 PM
drivers side heat junkdrawer E36 0 03-25-2008 12:34 AM
325i AC question about low side pressure Jammer3 E21, E30 2 06-07-2007 03:10 PM
E46 Drivers side outer door latch doesn't work seakengo E46 20 03-29-2007 01:33 AM
