Unread 07-19-2005, 06:40 AM   #1
528man
Womans trouble
I pulled beside this older woman at a gas station who was driving a 98 740i. I ask her how it was treating her (she seemed like the type to appreaciate the car) and she said the only problem was that sometimes her radio didnt work. Bmw told her that it was her amp and replaced it. The problem is still there every now and then. Anyone know?
1997 528i
Unread 07-19-2005, 08:30 AM   #2
I'm not sure if it's true of the 7-series, but I know some bmws have an issue with the sound system wires rubbing over the years and losing the protective rubber around them. Maybe some parts of the wire for the radio is getting thin and it's going in and out from that.
Unread 07-19-2005, 06:58 PM   #3
BMWLotAttendant
Title: I Drive EVERYTHING
Your Ride: 1997 Camry CE
Maybe she didn't type her radio code in properly. Hmmmm
Unread 07-19-2005, 07:03 PM   #4
craig
craig's Avatar
Title: Sitting in Time out
Send a message via MSN to craig
radio code?
Unread 07-19-2005, 07:04 PM   #5
BMWLotAttendant
Yeah, you have a card that tells the transmitter or whatever to work. Something like that.
Unread 07-19-2005, 09:58 PM   #6
Originally Posted by shpuz
radio code?
on newe BMW's the radios have a special lock code you can enable meaning you will need the code to operate the radio if its ever stolen or removed. its a really kool feature, never usued it myself though
Unread 07-19-2005, 10:34 PM   #7
craig
craig's Avatar
ah, i c. thanks for the info
Unread 07-20-2005, 01:27 AM   #8
Believe it or not even my e30 has this on the radio, if i ever press the wrong buttons while cleaning the car it beeps like crazy and every once and a while I need to enter my code, I guess it may also prevent the car from starting as well, never tried that though
Unread 07-20-2005, 01:56 AM   #9
///M Power
Rate My Car: 26 / 340
Your Ride: 95 m3 turbo
That's slightly different. The e34 and e30 have a code built into the OBC that people can use for anti-theft security. It requires someone to punch in a code in order to start the car. Somethign I believe Komodo is trying to build for himself right now. But nick you also mentioned the radio code, which my e34 has aswell. This is a code required to be put in, in order to allow the radio to work. Many of you have disconnected the battery for longer periods of time and realize that after you reconnect your battery you are required to put this code in for your radio to function.
But I don't see how she couldve put the code in incorrectly if it works some of the times. I wouldve guessed amp too because I know some BMWs also have that problem. Maybe just a shitty connection from harnesses/wiring.
Unread 07-20-2005, 02:09 AM   #10
Yes I have heard about making an antitheft code before, sounds like a big pain in the ass to do though, All i know is that i'm happy to know my radio code for those times when there are ocasional problems. Thanks for some clarification.
Unread 07-20-2005, 06:45 AM   #11
528man
thanks for the info guys. doubt i will see her again but i was just wondering what the problems may be
1997 528i
having trouble.... craig Geek Chat 6 08-22-2005 02:24 PM
Trouble Codes Spieluhr E36 5 05-29-2005 06:29 PM
Trouble starting car after sitting cold for 3 days..help!? delmarco E36 2 05-28-2005 09:26 AM
