Unread 07-30-2009, 03:11 AM   #1
kensta
kensta's Avatar
Your Ride: 2001 325i E46
e36 corner guides broke off
while installing my e36 headlights the corner guides broke i realized the i did not install them properly and they were out of alignment and the guides snapped when i puushed the corners in and had to basically force them in, anyone has a fix?
www.youtube.com/kenstaxboi
Unread 07-30-2009, 01:22 PM   #2
Captnpirate
Captnpirate's Avatar
Your Ride: 2001 M Roadster
serach for the ziptie method it works.
Unread 03-05-2010, 07:05 PM   #3
Phats701
Your Ride: 1997 540i
JBweld platic should work to reglue the guides on and make sure to align the headlights properly so you dont break the guides again
Unread 03-05-2010, 10:12 PM   #4
kensta
kensta's Avatar
i knew i had them in wrong.
i test fitted everything on the bench and it all worked then when i put them in the car they didnt so i forced them in and broke the guides.
maybe they broke because of the cold weather??
Unread 04-02-2010, 03:46 AM   #5
joshtimber81
Your Ride: BMW E36
When i had depos, I did them in the freezing cold. Never broke them.
Unread 05-16-2010, 10:37 AM   #6
JodyC
JodyC's Avatar
Your Ride: 2001 Z3
I dont get why people always break these? Obviously if you are applying enough force to them to break them then they obviously arent put in correctly. Why sit there and try to force something to the point that it breaks? Makes no sense at all. My depos looked better than oem and went in with ease.
Unread 05-16-2010, 05:35 PM   #7
Captnpirate
Yep, because of the way the lights are set up, you have to pull the light housing out and crank a turn or two and then replace the housing and test them. It took me several times to adjust not only the height but the L / R angle but once you get it, they are the best looking lights around. I run my eyes only during all but the brightest of days. Your Z looks great!
Unread 09-23-2010, 01:45 PM   #8
Silsurf
Your Ride: 04-330ci
Arrow
They look Irie
I have a set which bought last year and cannot find anyone to install them that will not charge a wheel and a muffler
Silsurf
WTB: e36 2 door left clear corner komodo Bmw Cars For Sale/Wanted 3 06-29-2006 01:03 AM
For Sale Window Regulator E36 Coupe defkon99 Bmw Cars For Sale/Wanted 0 06-18-2006 10:22 PM
