Unread 07-07-2005, 02:34 PM   #1
delmarco
delmarco's Avatar
Rate My Car: 227 / 340
Car Done! ABS code read, Brakes/Rotors checked out for $25!
So I took my car to where my girl takes her Neon.
And I went under the car with the guy, after they lifted it.
We concluded I need new rotors and pads on all 4 wheels within the next 500 to 1000 miles.
My shocks, struts, arms, balls, joints all checked out...so did everything else
Okay the ABS problem is still a mystery. Apparantly all the sensors are cleaned and working, the pump and entire ABS system looks and works fine, the computer read out that there was no problems with the ABS electrical system. The guy told me that only BMW would be able to check it out indept and reset the ABS light.
However, I the guy said my battery's negative connector was not clamped on all the way and was very loose (in fact he easily lifted the neg wire off the terminal point and the car went dead)...he said that could be the cause of the ABS light. A loose battery terminal can momentarily disconnect during a bumpy ride and I won't notice but the car's electrical system can be compromised. Anyway he tightened it and said that I could be the best cause of the ABS mystery.
Anyway I got all that done for $25 and I still gotta take my car to BMW next week.
Unread 07-07-2005, 03:11 PM   #2
RealBmw 02
Title: GRIP > DRIFT
Rate My Car: 76 / 340
Send a message via AIM to RealBmw 02
well at least the check up was cheap.
BTW, does your ABS work? I know the light is on, but it still might function properly
1970 BMW 2002
Driven by skill, not money
"Real BMW's have round tail lights"
Unread 07-07-2005, 05:31 PM   #3
delmarco
delmarco's Avatar
The light is usually off, but it comes on ONLY intermittenly when I'm parallel parking, driving slow, or u-turning for some reason. All I have to is restart the car and the light goes off.
It's still a mystery!
Unread 07-07-2005, 10:04 PM   #4
It's haunted.
Unread 07-08-2005, 12:21 AM   #5
delmarco
delmarco's Avatar
So it is confirmed the light definately ONLY comes on whiles parallel parking and/or u-turning (like in a narrow street). It may have to do with back and forth reversing and driving at slow speeds...which is basically what parallel parking and u-turning is.
Somehow this is setting the ABS light on.....
does anyone know why?
Unread 07-08-2005, 02:35 PM   #6
xxxbimmer
Rate My Car: 48 / 340
strange...... my abs sensor is bad and my abs light comes on when im going slow and parking
Unread 07-09-2005, 08:24 AM   #7
delmarco
delmarco's Avatar
Interesting...but are you sure it is due to a bad sensor?
If so then I may have a bad sensor.
Unread 07-11-2005, 04:01 AM   #8
Spieluhr
Title: ///M Driven
well one connection I made is that when you make U-turns and parrellel park, both of these actions require that you steer all the way in one direction. I honestly don't know how this connects to the ABS, but it may be something to consider.
Unread 07-11-2005, 11:54 AM   #9
bimmerdame
Your Ride: 2001 325
delmarco, where did you get your sensors checked??
Unread 07-11-2005, 04:24 PM   #10
delmarco
delmarco's Avatar
a Lube Place behind the Mobile Gas Station
24 01-22-2008 05:54 PM
You Might Be a Ricer If.... komodo Comedy Collection
20 11-08-2006 11:06 AM
checked out a car today brien4787 E36 10 08-02-2005 01:04 PM
