Skyler O'brien Now On ITunes
Sponsored by: SKOB on itunes
Unread 06-30-2005, 12:02 AM   #1
cu89e30
Your Ride: 1989 325i
Question e30 wiring harness
does anyone have a radio wiring harness diagram for a 1989 e30 325i?
Unread 06-30-2005, 05:21 AM   #2
At the Head Unit:
Constant 12V+ Red/White
Switched 12V+ Purple/White
Ground Brown
Antenna White
Rt (+) Blue
Lf (+) Yellow
Rt (-) Blue/Brown
Lt (-) Yellow/Brown
At the Fader Control:
Rt Front (+) Blue/Red
Lt Front (+) Yellow/Red
Rt Rear (+) Blue/Black
Lt Rear (+) Yellow/Black
All (-) leads should be further down this wire harness, or follow each to their respective speakers to find the (-)'s.
HTH
Unread 07-23-2006, 06:02 PM   #3
Note: Stuck this for a while cause it was buried
Unread 04-23-2007, 12:59 AM   #4
maximk2
Your Ride: 1993 325i
At the Head Unit:
Ground Brown
Antenna White
Rt (+) Blue
Lf (+) Yellow
Rt (-) Blue/Brown
Lt (-) Yellow/Brown
Sorry, but what do you mean by"fader control"?
Unread 04-23-2007, 01:17 AM   #5
elsabor67
elsabor67's Avatar
Rate My Car: 35 / 340
Fader control is a little button (sorta) that when turned would fade either to the front or back speakers. Not all BMW's came with it, as mine didn't have that option.
How do I spell relief??
AUTOBAHNNNNNNNNN
"GO FASTER !!"
Unread 04-23-2007, 07:46 AM   #6
celsdogg
celsdogg's Avatar
Title: never gonna happen
Rate My Car: 131 / 340
neither of mine did either.
it was a button/switch that was next to the hazard and rear defroster buttons.
Unread 04-23-2007, 10:53 PM   #7
maximk2
What I am having a big problem with is putting a deck in my 93 325i. Everything seems right by the deck- there are different sets of wires, seems like each set would go to a speaker (now i did find all the proper deck-powering wires. When i start hooking up the speakers.....well.....nothing happens. For example, the front right speaker uses blue wires. There are two of these wires that i can hook up to the deck, but there is also a tweeter, which is hooked up by its own set of wires by the speaker. Each set i found in the door panel was blue but had different color stripe than the ones by the deck. This makes me assume that there is some kind of amp or hub that would create all these tweeter leads. If so, where would it be so i could beat the living fuck out of it for leaving me without music all weekend long?
PS- actually i would just prolly make the damn thing work properly
Unread 05-08-2007, 01:24 PM   #8
1985 325E
1985 325E's Avatar
Your Ride: 1985 325 E
I too am running into an issue. Seems the Bimmer I bought HAD a power antenna, but the previous owner removed the motor. I was trying to re-install a power antenna, however the "wire" that comes out of the back of the deck, I do not know which wire to hook to. Color's I have seen in previous postings seem to all say white. Is it plain white? No lines or stripes on it? I have the antennea installed, and hooked up in the trunk, but I can't get switched power to it.
Unread 05-08-2007, 01:43 PM   #9
my antenna wire is just coaxal type cable.
Unread 05-08-2007, 03:54 PM   #10
celsdogg
celsdogg's Avatar
^^^ it is white. the white lead is what tells the antenna to go up. the coax is for the actual receiving the signal with the antenna.
Unread 03-29-2009, 01:16 AM   #11
calvin707
Your Ride: 1986 BMW 325es
E30 Wiring Harness / Deck Upgrades
Hey all, new member here, first post. Just picked up a beat up a 1986 325es and I went to try and swap out the factory deck for a new Kenwood model, and ran into a bunch of problems.
Read all the posts on here, AFTER I did most of the work already. So far I've removed the fader unit, the factory amp and am working to rewire the whole thing with a new deck, new speakers, new amp and sub. It's quite a pain!
If I can answer any questions let me know, I think I kind of reinvented the wheel here, but lots of good info online as well.
Thanks!
Dan
My 97 Camry vs an e30 325e BMWLotAttendant Kill Stories 18 10-26-2005 12:38 AM
Nakamichi wiring harness.... Numark318i Car Audio and Electronics 1 10-24-2005 09:40 PM
Buying a E30 but what Model? defkon99 E21, E30 20 08-02-2005 01:01 PM
I think im buying an e30 catalyst E21, E30 13 07-19-2005 05:54 PM
Pics of am HU and harness? Nics Car Audio and Electronics 1 05-04-2005 09:07 PM
