Unread 12-02-2010, 06:22 PM   #1
jjernig
Your Ride: 1996 328i
brake light failure
First timer here, first bimmer for me as well.. thanks for input!
this is 1996 328i one brake is failing... have replaced the bul and socket works on the opposite side. looks like the housing is slightly burned, possibly not full contact there with the bulb socket. Is there a way to resolve this without complete replacement of housing?
Unread 12-02-2010, 10:30 PM   #2
I have repaired a couple of these over the years by pulling out the tail light (takes some persuasion if it has never been removed) and soldering the damaged trace and grinding it smooth with a dremel tool. Probably not a permanent fix, but they are holding up so far.
Brake Light Circuits cruzn4abruzn E36 6 12-08-2014 09:01 AM
'96 328is: 2 gauges go down + Brake Light Circuit Error = Now car won't start!! foaxaca E36 9 07-07-2010 01:09 AM
Brake light circuit fault message 3050rpm E36 4 05-20-2009 01:16 PM
Brake light HyeTide E21, E30 3 11-11-2008 08:13 PM
