Unread 11-12-2010, 08:05 AM   #1
goforit
Your Ride: 318i
Question '94 318i M42 loosing water
Hi,
My '94 M42 318i appears to be blowing water (coolant) out the exhaust. I don't see any blackening of the remaining water or see any water in the engine oil? Could it still be a head gasket? What else could it be? Is there another way that it could be getting to the exhaust? I'll pull the plugs tomorrow and see if there's a difference between them? Are head gaskets or anything else that could cause this a common problem for these engines?
Thanks,
Unread 11-12-2010, 11:49 AM   #2
Water in the exhaust is a pretty clear indicator of a blown head gasket. I'd first check for just condensation in the exhaust but if you're losing coolant and it's not boiling over or a leaky system. Then it would be going out through the head gasket into the cylinders and out the tailpipe.
Unread 11-13-2010, 06:30 PM   #3
goforit
Your Ride: 318i
All spark plugs look the same. As background the car sat for six months or more before this. No external leaks. I've marked coolant level to see if it as moved when it cools down. Coolant also looks clean?
Unread 11-19-2010, 02:30 PM   #4
Depends on the failure. But if you're getting coolant out the exhaust it HAS to be getting there somehow
Unread 11-20-2010, 11:17 PM   #5
If the car runs OK and the coolant looks OK, then I am going to put my money on even worse news. I vote cracked head. Let us know what you find.
Detailing techniques and products... ivopivo Detailing and Cleaning 2 09-15-2009 01:51 PM
'94 318i will not crank, EWS?? goforit E36 1 09-07-2009 05:52 AM
94 318I testing waters travis0583 Bmw Cars For Sale/Wanted 0 12-28-2007 04:22 PM
Water vs. Coke brien4787 United Off Topic  **FOR MEMBERS ONLY** 1 03-25-2006 01:07 AM
What is the avg. lifespan of an Auto M42 E36 318i? delmarco E36 15 05-31-2005 11:09 PM
