Unread 10-11-2010, 03:47 PM   #1
Hg750
Your Ride: 1990 750il
e39 540i steering shake
I recently got my tires balanced and rotors turned because of vibration and shaking in the steering wheel. The steering wheel still shakes from 50 - 55 mph and when I press the brakes, the steering wheel shakes bad. If anyone has had problems like this, info would be greatly appreciated.
Unread 10-20-2010, 07:59 PM   #2
95325i
95325i's Avatar
Rate My Car: 292 / 340
Your Ride: 1997 540IA;2001 Z3 3.0 Roadster
Send a message via AIM to 95325i Send a message via MSN to 95325i
More then likely it is the bushings on the thrust arms. They tend to be one of the fastest things wear out over time on the E39 suspension.
1997 540IA
Unread 11-05-2010, 12:49 PM   #3
Bingo. Had an older 5 that did the same thing, that's what caused it. Replace the control arms (all of them most likely), maybe the shocks and get it aligned following the repair. SHOULD solve you problem
Unread 05-17-2011, 03:01 PM   #4
zebula
Your Ride: 1998 BMW 540i, 1997 BMW 740
I concur, had to replace them on mine as well. Boyfriend has a 740 and he had the same problem. Replace the control arms and you should be all good.
I called it the bimmer shimmy...
Unread 06-21-2011, 06:34 PM   #5
macky55e34lover
macky55e34lover's Avatar
Your Ride: BMW '94 E-34 525i
i agree, the bushes and the joints usually wear out
1994 540I Power Steering Hose Routing Consejero E12, E28, E34, E39, E60 0 06-19-2010 12:50 PM
e39 540i Lacks Power, sends codes p0150, p0155 and p0170 Schwartz540i E12, E28, E34, E39, E60 3 06-19-2010 10:05 AM
ABS, ECU? E39 540i phantomsys E12, E28, E34, E39, E60 1 07-05-2009 06:20 AM
1997 BMW 540i E39 Part Out! ruskiepatzan Bmw Cars For Sale/Wanted 1 01-22-2007 06:53 PM
