Unread 09-11-2010, 08:35 PM   #1
Whiteshark535
Whiteshark535's Avatar
Rate My Car: 283 / 340
Your Ride: 1989 535i
New week new problem
My ABS light issue solved itself, ...for now anyway. The week before it was a waterpump.
The other day on the way back from lunch I noticed my car sounded like it was sputtering, it was ok at idle but under any kind of load it started to sound like an old sputtering dumptruck. I did a quick check to make sure all my plug wires were on securely, they were.
Today I had more time to look at it, so I inspected all the wires, took off the cap and rotor, all looked ok. I loaded up with Super Unleaded and a bottle of fuel treatment/injector cleaner since I was just about on empty. If it is a fuel system problem I know it might take a few days to run any bad gas out of the system so I am keeping my fingers crossed.
It sounds like it is running on 5 cylinders, I am wondering if one of the injectors is clogged or just not working. Does anyone know if a clogged catalytic converter would produce these symptoms? My temp. has not been any higher than normal. Any advice, ideas, comments welcome.
Unread 09-13-2010, 06:59 AM   #2
macky55e34lover
macky55e34lover's Avatar
Your Ride: BMW '94 E-34 525i
we need diagnostics dude - OBD, computer, the works. it will help you give an idea on faults of the system, specifically the sensors (ex. a faulty or wet crank sensor would cause your engine to sputter, better check the contacts of the airflowmeter, sometimes the connectors get so dirty that the car idles rough then stops
Unread 11-13-2010, 06:41 PM   #3
Whiteshark535
Unhappy Update
Tried the stomp test numerous times, never any codes. Replaced the crank position sensor today the old one was in bad shape, the boot was torn and several wires were exposed and broken, thought this would fix it for sure. No such luck, still runs like crap. Anyone?
'90 e30 ignition problem dawson E21, E30 1 04-06-2010 02:34 PM
1980 732i E23 Battery Drain Problem HJMAX732i 7 Series (E23, E32, E38, E65, E66) 0 06-19-2009 10:57 PM
325 brake light problem fgmx Lighting 2 02-01-2008 02:52 PM
Might have a problem with my dealer nick_318is E21, E30 2 03-24-2006 12:54 AM
