Unread 09-02-2010, 12:02 AM   #1
nhevynopal
nhevynopal's Avatar
Your Ride: 93 318is
hey guys i got problem installing shark injector
i encounter a problem i was woundering if u guys can help as i was installing the SI. i got to the point were it tells me that in approximately 1 to 6 minutes the red active led will turn on while the green status led continues to pulsate indicating that the shark injector is entering the reprogramming phase....but the green led turns off and only the red remains flashing i thought it was part of the proses but i waited 2 hours and nothing waiting for the green led could it be lack of battery voltage i dont want to continue without advise
Unread 10-02-2010, 02:35 PM   #2
jwbavalon
jwbavalon's Avatar
Your Ride: 1997 M3
Hi, you will need the battery charger as mentioned in the FAQ. The uploading procedure needs more voltage than the battery alone can supply. I tried an automatic battery charger and it did not work and not having a manual battery charger, I used another running car as done in a jump start situation. It uploaded in no time and I've not had any problems since the upload..
Hey guys kandasx301 Introductions and Greetings 1 10-09-2008 05:45 PM
Very important, Alarm install, Shark injector, and custom fiberglass lip!? BaLAnCe17 E36 8 08-14-2006 11:39 PM
Hey Guys komodo United Off Topic  **FOR MEMBERS ONLY** 16 05-05-2006 01:12 AM
Hey Guys Rooz Introductions and Greetings 7 04-19-2005 06:09 PM
