Unread 08-29-2010, 11:04 AM   #1
rollacoach
Your Ride: 1995 740i champaign
95 740i aux fan problem
hello i have a 95 740i and have never seen the aux fan in the front of the radiator run. the car doesnt over heat but i notice on hot days the ac isnt the greatest. which i believe is because the ac head pressure gets too high i dont know where the relay is can someone walk me through where the relay is. thank you
Unread 09-03-2010, 01:40 AM   #2
b57jetmech
Your Ride: 1998 BMW 740i
Might not be a relay. take a look at the fusebox in the engine compt. There is a 50 amp fuse buried deep in the covered box that powers the fan! Take a look at it, it might be the source of your trouble.
Unread 09-03-2010, 04:38 PM   #3
rollacoach
thank you that was it now the fan came on several times and hasnt come on in a while yet the fuse is good. how does that fan function. does it only come on when needed or does it have a sensor that may be bad? if so do you know where that sensor may be or how do i check it?
thank you for all your help
aux A/C fan problems tm11nia E12, E28, E34, E39, E60 2 08-20-2010 02:14 PM
E36 fan delete mod and now aux. fan does not work fxoaxaca E36 2 08-14-2010 01:04 AM
Aux fan relay stevieL 7 Series (E23, E32, E38, E65, E66) 0 01-30-2010 03:50 PM
help with A/C and AUX fan eightynine535 E12, E28, E34, E39, E60 14 08-28-2007 09:57 PM
A/C Problem -Aux fan stops Siaren Z Series (Z3, Z4, Z8) 11 05-17-2006 10:03 AM
