Unread 08-12-2010, 08:18 AM   #1
writerdude
Your Ride: 1994
Post 1994 525i Mystery Fan Will Not Shut OFF!!! HELP!
I have a 1994 525i that was running great! This Saturday a fan that seems to be under the fuse box in the engine bay will not shut off. It almost drained my battery before I just disconnected the cable. ( pain in the ass since the battery in under the rear seat!).
It runs whether the car is on or not! ( note it is not the auxiliary fan I pulled those fuses and it still came on)
I have researched this but the data is mixed, my Ac and Heat work just fine, we have 100 degree days here and the AC is doing it s job, so does anyone have any ideal how to turn this bugger off?
Currently I have to disconnect the battery cables to keep the fan from killing my battery. Is there a fuse I can pull, the fan is strong, so strong you can feel the vibration all over the car when it is running.
Thanks for any assistance anyone can provide.
Unread 09-25-2010, 08:57 AM   #2
macky55e34lover
macky55e34lover's Avatar
Your Ride: BMW '94 E-34 525i
i think it's the fan that cools the computer box and keeps it from overheating, i think something is shorted with the wires that's the reason why it's always on, better have it checked by an expert electrician so that it will not drain your battery all the time.
Unread 09-25-2010, 10:16 AM   #3
writerdude
Your Ride: 1994
Thanks, just like it turned its self on, it just stopped. I think the extreme heat we had this summer, may have played a role. Once the temperature dropped it shut off.
Unread 09-28-2010, 12:41 AM   #4
macky55e34lover
yes, that could happen, good to know it's ok now
Unread 05-23-2011, 07:22 PM   #5
GDJ
Your Ride: STILL SEARCHING FOR ANOTHER BMW
Might be a bad relay. Most of the fans are relayed (they draw a fair bit) on our cars. Might be worth checking that out.
1994 530i 5 speed - RIP due to a dipshit that can't do overshoulder checks and ran over the front end with his Jeep!
1989 325i - RIP due to a knucklehead that rammed the car in the butt doing 50 km/hr while I was stopped at a intersection!!
New ride: 1998 318i
E36 fan delete mod and now aux. fan does not work fxoaxaca E36 2 08-14-2010 01:04 AM
Removing starter BMW 525i 1994 claytoncps1 BMW General Discussion 1 07-27-2010 10:17 PM
Pictorial DIY: BMW E46 Fan Clutch Removal & Engine Belts Change For Automatic Cars delmarco E46 4 04-29-2010 03:16 PM
1994 525i will not start faloon52 E12, E28, E34, E39, E60 9 04-18-2010 01:47 AM
1994 525i will not start faloon52 5-Series 0 10-05-2009 06:02 PM
