Unread 06-05-2010, 07:26 PM   #1
What is the F-d-d-d-d-d-d-d Vibration??
1997 328 Automatic, 150k miles
80 mph or higher, a slight left curve makes the whole car shake and make a noise like it has gone off on the shoulder and hit the rumble strip - but the highway is smooth.
If I floor it in first gear, there will be a brief 1-second bout of the same noise. It feels and sounds rather as though the antilock brakes were engaging, except the car is not slowing down, it is accelerating hard.
I disengaged the ASC and tried the low gear acceleration - no change.
The sound and frequency of the vibration makes me want to focus on the antilock brake system, but that should not engage unless the brake is pressed, right? I have no warning lights lit.
Thanks for any suggestions.
Unread 06-08-2010, 02:52 PM   #2
Check your driveline for the all to common center support bearing blowing out. There's other stuff too but start there
Unread 11-15-2010, 11:01 AM   #3
acelnah
Your Ride: z3
My car would shudder like rumble strips in second gear, up a hill at times ect.. I changed my rear breaks fixed the problem. Did not have to do anything else.
Unread 11-16-2010, 12:57 AM   #4
This one turned out to be the front right outboard ball joint. I replaced both control arms. Tightened everything up nicely.
I was so pleased with the tighter handling that I put new control arm bushings on the other '97 as well.
Wierd vibration at high speeds projal147 E36 24 07-24-2010 02:43 PM
Rear Vibration scarey E46 0 01-20-2009 01:26 PM
E39, 2001 build year with vibration problems havocmil E12, E28, E34, E39, E60 1 02-22-2008 04:27 PM
vibration on my car max79 E36 3 01-07-2008 07:12 PM
vibration when braking Davey D 67 E46 2 06-14-2007 09:15 AM
