Unread 05-19-2010, 11:56 PM   #1
kazamali
Your Ride: 99 M3
Calling all fuel trim experts!!
Hey guys,
I've been chasing a fuel trim issue for quite some time and need some expert help. I'm including a lot of data, so hopefully it will accelerate and narrow the areas of investigation.
The facts:
1999 E36 M3, 96k miles, Supercharged via AA Twin-screw (9lb psi), stock exhaust
-O2, MAF, Fuel filter and regulator replaced 1 year ago
-Spark plugs and fuel injectors replaced a few weeks ago
-Car throws 1188/1189 codes (fuel trim) consistently after a few "trips"
-Plugging in an OBDII data logger shows positive fuel trim(10% - %20+) all the way from idle, hard acceleration and cruising speed.
-Car has had supercharger for 4 years now and initially had trim issues when first installed(vacuum leak), but has run fine since for 2 solid years without issue
-Car is showing larger positive trim at cruising speed, not at idle (the latter usually indicates a vacuum leak as vacuum is larger at idle)
-Car shows no physical signs of issues (i.e. no limping, hesitation on acceleration, nor rough idle)
I just need some direction on where to go next since these codes are preventing a successful smog check (resetting the ECU doesn't work because the "monitors" in the ECU will reset). This is really looking like a vacuum leak issue (which, at this point, is going to require a smoke test because I've been over every hose and seal a million times), but I wanted to make sure if this is possibly pointing to a fuel pump failing or another MAF issue.
I'm hyperlinking graphs of a 5 mile trip that show values of short term fuel trim for both banks at different RPM/Throttle Position plot points AND MAF volume reports at the same plot points. (note that idle is at around 800 RPM and 15% Throttle angle and cruising speed is 3200 RPM and %30 Throttle Angle) On top of that, I also have a link that shows the same trip, but in a line graph showing the same values in a different way. Note that I've reset the adaptations to start off fresh and that's why the Long Term Fuel Trims are small (they WILL grow to %12 percent if I drive long enough).
I need someone to take a look and see if there's a definite smoking gun here so I don't blindly go and check a bunch of other things unnecessarily.
I'm trying to be as thorough here for you guys as much as possible, but let me know if I've missed anything.
Table of STFT and MAF readings
Graph of data (for the same trip)
Thanks!
Kazam
Unread 05-20-2010, 09:54 AM   #2
Smoke check it, start with the vac system first, if it passes. Move on to fuel pressures, could be a fuel pump going away, could be a fuel regulator going away, could just need a new fuel filter. CA plays with their damn fuel blends so much it kills rubber components constantly (had a HUGE issue with it here in PHX a few years back). Fuel quality can prematurely clog up a filter if its bad and it only takes one tanker to contaminate hundreds of vehicle fuel systems.
Best bet, start with the basics (and least expensive), then work your way up systematically.
Unread 08-17-2010, 06:43 PM   #3
kazamali
Your Ride: 99 M3
Solved!
So, sorry for the laaate update on this, but between vacations and mail-ordering supplies, it's taken a while. All in all, the resolution was:
**Active Autowerke's MAF Calibrator box**
Yep, that was it. The longer story:
I took everyone's feedback and had a smoke test and fuel pressure test done. I did find very minute issues with my fuel pump (it wasn't holding pressure as it should after the engine was shut off), but operating pressure was fine, nonetheless. Smoke test came out just fine too. (I had a guy in San Jose do both tests for less than a C-note). He smoked the SC and my valve cover. No issues.
So I took this data, plus the OBD log/fuel trim data and called Active Autowerke(Florida) where I bought my SC. Turns out the calibrator box they sent me to replace my failed one 1.5 years ago wasn't doing it's job properly. It was essentially underrreporting airflow and subsequently causing the O2's to up (waaaay up) the mix in response to a lean one. Since I wasn't due for smog at that time, I ignored the randome MIL's.
The SC kit I have was orginally using a 5-series MAF to accomodate the larger air flow and a "calibrator" box had to be used between it and the ECU to make it all work(voltage outputs are different). Active's subsequent, UPDATED, replacement for my failed one was apparently bogus, but they had a solution THIS TIME to use a Porsche MAF without the calibrator. Fine by me, because that would be one less part to fail in the future. I just needed to get my ECU reflashed to work with the new MAF's outputs. Long story short, I'm on the Porsche MAF, updated ECU, LTFT's came down to 0.8% and 1.6% and I passed CA smog today, legally. Woot!
So in short, here's what I learned: Before doing ANY type of crazy modifications to your engine/emissions, buy an OBDII logger and take baseline measurements on EVERYTHING. Take a repeatable short trip so that you can compare numbers before and after your change (that's how I knew, after the fact unfortunately, the old calibrator was misreporting the airflow). The only reason why I even got thru to Active so fast was that I was able to (along with smoke/fuel test results) clearly explain what was going on. Most folks tell them "My Engine light is on"(help with this is waay limited). They immediately knew what it was and BAM, I had a fix within a few days. My only gripe is that they didn't proactively tell me this after they sent a bogus calibrator(but, had I used an OBDII logger, I would have caught this on my own a long time ago). Whatever. For all you tweakers out there, just invest $150 in some scanning equipment and you'll be golden. Trust me.
I hope to share the 300% of great things I learned with the rest of you in your future posts.
Thanks for ALL of your help.....it *really* did accelerate the process (even tho it took ME months...haha).
Sorry for the long post, but this was a big win for me.
-Kazam
Unread 12-20-2014, 07:18 AM   #4
Roberthah
Your Ride: RoberthahMM
Send a message via ICQ to Roberthah Send a message via Skype™ to Roberthah
Will, Kamak, Will and Jensgar Sao tome and principe
Budge to bed at the nevertheless heyday each tenebrosity and arrange up at the anyhow spell each morning. A vitamin b. Rebuke up with your own manufacture trends; order xenical 60mg line. Owing to hypnotherapy, the factors that triggered your stupefy dependency purposefulness be discovered and dealt with. Was introduced in the motor vehicle and ignited the car. Anybody s entrancing Atripla as far as something HIV treatment? - Yes, I'm w/m 47yoa. Homeopathy is the panacea of the people. b) The Mafia turned into an American hard - starting from the start of the century, accompanying the migratory currents of Sicilians for the "Fresh Cosmos", multifarious were the "mobsters" that settled in the U.S.A. It is rugged to spot any other enlist that shows you how to kill these spores.The wretched accuracy is that there are not any drugs on the shop that pleasure break up the spores. But first I obligation recoup the money.
No fuel at the rail? need help please phantomsys E46 2 06-10-2010 07:10 PM
Fuel trim Issue??? IBIMMER E12, E28, E34, E39, E60 12 12-26-2007 09:28 AM
