Unread 05-18-2010, 04:06 PM   #1
cooter67x
Your Ride: 92 325i / 94 325is
Cool brake light issues
if my 3rd brake light works when pedal is depressed and the others do not is that in the switch or bulb sockets, OBC is giving circuit fault and light fault. also how do you switch the language on the OBC from german to english or does it have to be replaced.
Unread 05-18-2010, 06:13 PM   #2
ireestar
ireestar's Avatar
Your Ride: e36 m50/m3 turbo 1994
replace the unit mate there very ceap now days and if the center brake light works it would be the bulbs or the lamp track as ive had thisproblem and change the rear lamp for a ew unit........IREE
Unread 06-03-2010, 01:24 AM   #3
DSP543GP
Your Ride: 1993 320i
Hi Guys!!!
My e36 obc tells me "1 brake light failure" report, I checked all my bulbs are fine I also changed the offset bulbs with new one but I still get the "1 brake light fail", is there a way to sort this out? I know Ireestar can help with this, others you are also welcome to comment. Thanks
BMW e36 320i
E46 Light Alloy Wheels
Everything standard and original
Unread 06-22-2010, 11:00 AM   #4
joeyp770
joeyp770's Avatar
Your Ride: 1992 325is
Send a message via AIM to joeyp770 Send a message via Yahoo to joeyp770
Originally Posted by DSP543GP View Post
Hi Guys!!!
My ride does the same thing. I think it is an issue with the trunk wiring harness. Look for the post about "Brake Circut Failure". I think there is a pretty easy fix.
Unread 06-22-2010, 12:18 PM   #5
DSP543GP
Ireestar!!! Which switch are refering to, the brake switch is under the steering wheel?
BMW e36 320i
Unread 07-01-2010, 02:13 AM   #6
DSP543GP
I've just replaced my brake switch under the steering wheel but I still get the "1 Brake light fail" report, any advise?
BMW e36 320i
Unread 07-12-2010, 03:28 AM   #7
DSP543GP
Hi Guys!!!
I've changed the brake switch with good used one, which was much better than mine, the "1 brake light fail" message would disappear and appear after some time. Is there a way to reset it, cause my bulbs are all working? I'm definately sure that it's not the brake switch issue now.
BMW e36 320i
'96 328is: 2 gauges go down + Brake Light Circuit Error = Now car won't start!! foaxaca E36 9 07-07-2010 01:09 AM
Brake light circuit fault message 3050rpm E36 4 05-20-2009 01:16 PM
Brake light HyeTide E21, E30 3 11-11-2008 08:13 PM
Brake check light wb00 E21, E30 4 01-23-2007 10:53 PM
