Unread 05-17-2010, 03:05 PM   #1
alphaomega
Your Ride: 1999 323i
Unhappy Trunk Door unlock button not working
Hello guys,
I have a 1999 323i and I don't know why I don't have a internal switch to open the trunk, there is a button under the trunk door handle that you press and it opens the trunk and it is not working. I already tried to fix it but I opened everything but nothing looks wrong. The control key is the only way i can open it but now I lost it. Does anybody knows how to fix the button in the trunk? any clue?
thankx
Unread 05-20-2010, 04:55 AM   #2
bigdaddyal77
Your Ride: 2004 325CIC
If the glove box is locked, it will not work. This is a safety that was added for Valet service to prevent them from plundering through your stuff.
Unread 05-20-2010, 01:25 PM   #3
alphaomega
I never lock the glove department, any other clue?
Unread 05-21-2010, 11:02 PM   #4
bimrpwr
Your Ride: 93 325i and 99 Passat 1.8t
maybe your button is broken....once you get it open rip things apart so you can look at the hookups.
Unread 05-25-2010, 03:33 PM   #5
alphaomega
Unhappy
I already did that and everything looks great.
Unread 09-16-2010, 07:40 AM   #6
errol325i
Your Ride: 2003 325 i
Trunk door unlock button not working
I have a 2003 325i with the same problem will let you know solution after i fix it
There could be a bad ground where the license plate lights are on the trunk
Fixed!!! Trunk wont open 318i johnjackson80 E36 1 01-02-2010 03:36 AM
Random bulbs stop working after taking trunk light out chaz110789 Lighting 0 04-11-2009 02:09 AM
Ultimate DIY for 18 Button OBC Upgrade from 7 or 11 Button OBC Made Easy w/ Pictures! delmarco BMW OEM Parts Department DIY's & FAQ's 7 12-08-2008 08:39 PM
R/T button is not working Noshad E46 1 01-29-2008 10:28 PM
Trunk Will not Open, any ideas nick_318is E21, E30 6 08-14-2005 01:21 PM
