Unread 04-18-2010, 11:09 PM   #1
bimmergreg
Your Ride: 2001 M3
01 m3 code help!
Hey i have a 2001 bmw m3 woth 76000 miles, recently my service engine soon light came on. the codes i was seeing were;
P0304 (cylinder 4 misfire)
P0305 (cylinder 5 misfire)
P0306 (cylinder 6 misfire)
P0300 (multiple misfire detected)
P1585 (misfire with empty tank)
P0174 (system too lean on bank 2)
P0157 (O2 Sensor circuit low voltage (bank 2 sensor 2))
I have been reding through some other forums and someone had most of all of those codes right after they had cleaned their MAFS. They ended up getting a new MAFS and the codes didnt show up again. So i though maybe it was my MAFS and decided to take it out a clean it with MAF sensor cleaner. I then waited for it to dry than put it back in and cleared all the codes to see if it helped.
I then drove it for a while and got 1 more code within the next days.
P0175 (System to rich bank 2)
Does anyone know what i should do?! what do people usually do when they have this problem? Is there a sensor or something that usually goes out around 75000 miles? Does this happen often?
Unread 04-28-2010, 10:48 AM   #2
M3RACR
Your Ride: 1995 M3 (Auto)
Did all of the codes come up again + the P0175? Or just the P0175? I suspect they all came back...
Unread 04-28-2010, 03:21 PM   #3
bimmergreg
Your Ride: 2001 M3
No just the p0175 does very soon after i clear the codes. but now i've driven it for about a week or 2 and i checked codes again.
than i got
P0174 - system to lean bank 2
P0154 - O2 sensor circuit no activity detected (bank 2 sensor 1)
P0157 - O2 sensor circuit low voltage (bank 2 sensor 2)
right after the codes are reset. within 5 to 10 minutes of driving p0174 - system to lean bank 2 comes right back on.
Unread 04-28-2010, 04:04 PM   #4
M3RACR
if I were you I would change the O2 sensors, since they are giving you erratic fault codes. It's expensive, but if they have never been changed, it's time.
Unread 04-29-2010, 06:21 PM   #5
bimmergreg
Your Ride: 2001 M3
alright sounds good thats what im thinking because i have been drivin around for a few weeks than checked the codes again and got..
im wondering if you think i should replace both bank 2 sensors? and if so do you guys would know which ones they are so that i will know which sensors are bad. Because im not sure how they do the bank 1 and 2?
for 02 sensors there is 4 it says... (even though i've only seen 2 of them)
front manifold - before and after cadalytic converter
rear manifold - before and after cadalytic converter
do those refer to as the first 3 cylinders = front manifold?
and 4,5, and 6 = rear manifold?
thanks!
CT/DE/NJ/NY/PA BMW Meet 10/14 @ 12pm in NJ pinkfl2511 Northeast Region 4 03-22-2009 09:29 PM
Money Shift Information bimmersunited BMW General Discussion 1 12-23-2007 06:08 PM
CT/DE/NJ/NY/PA BMW Meet 10/14 @ 12pm in NJ pinkfl2511 Northeast Region 3 10-11-2007 05:24 PM
M3 SMG vs Mini Cooper S komodo BMW General Discussion 1 10-31-2005 12:18 PM
History of the M3 komodo United Off Topic  **FOR MEMBERS ONLY** 9 06-05-2005 06:16 PM
