Unread 04-07-2010, 09:05 PM   #1
Ebby1600
Your Ride: 2006
Oil seeping under valve cover gasket.
I got an engine indicator light for an oil change. It's an hour to the dealer, a day without the car, another hour to pick it up (each way) so I decided to change my own oil. That went well and I also reset the oil indicator light. What gave me some concern was I saw oil around the valve cover seam. It looks like BMW uses silicon valve cover gaskets and after 70000+ miles oil has found its way between the head and the gasket.
I wiped it down with a rag and will monitor the situation. Any posters out there have a similar experience? Remedy? The car is running great.
06 325XI Automatic.
Thankss
Unread 04-08-2010, 02:33 PM   #2
Check this out, the Pelican people have some very good technical advisories...
http://www.pelicanparts.com/bmw/tech...alve-Cover.htm
Replacing valve covers, leaking oil 740iguy 7 Series (E23, E32, E38, E65, E66) 3 02-07-2009 01:14 PM
Oil pan gasket replacement on 97 540iA IBIMMER E12, E28, E34, E39, E60 2 02-05-2008 09:18 PM
Oil Pan Gasket Mercenary(FH) E36 3 09-20-2006 05:42 AM
Valve cover leaking oil? billycuth E36 10 07-26-2006 12:05 PM
s52 valve cover vs m50 valve cover cabrit E36 5 06-22-2006 02:30 PM
