Unread 12-27-2009, 10:20 PM   #1
johnjackson80
Your Ride: 1997 bmw 318i
Thumbs up Fixed!!! Trunk wont open 318i
Hi all and thanks to those that tried to help with my problem...( trunk wont open 318i )
Well I finally got around to fixing the trunk by the following fix.
I used a 50mm holesaw using the coordinates of 40mm right of the lock barrel on the trunk and 70mm down from the number plate lights.
I then drilled the hole and simply got the connecting rod that had come away from the main barrel and pulled upwards to open the trunk.
Once open I unclipped the carpet to expose the the area and set about to reposition the rod and secure same using 3 zip ties.I then plugged the hole with a condiment lid that fitted the hole.
(I will repalce the lid with a rubber grommet when shops reopen after Xmas)
Finally I rescrewed the number plate back into place and hosed off the area..ALL DONE!
Regards to all and pics are attached...JOHN
Unread 01-02-2010, 03:36 AM   #2
johnjackson80
I made a typo error in my post in saying I used a 50mm holesaw ...that should read 25mm holesaw. Also dont forget to treat the cut area or it will rust.
HELP! trunk wont open on 318i johnjackson80 E36 4 12-24-2009 01:05 PM
Boot not opening 318i sedan 1997 johnjackson80 E36 3 12-12-2009 02:08 PM
92 318I Mystery For Me and 25 Yr Mechanic BShadows318I E36 17 07-20-2009 08:22 AM
dual 10" subs in the trunk of 325i E30 Neilsen Car Audio and Electronics 2 01-30-2008 08:40 PM
Trunk Will not Open, any ideas nick_318is E21, E30 6 08-14-2005 01:21 PM
