Unread 11-17-2009, 10:14 AM   #1
macky55e34lover
macky55e34lover's Avatar
Your Ride: BMW '94 E-34 525i
Cool Hard starting M50
I have a '94 525i-M50, apparently, the car is hard to start at times, even if you were able to use it already. It will take around 3-5 times before the engine would run. I use it everyday and it is a good drive specifically on the highway. A concerned friend also saw the problem and told me that the crank sensor may be faulty and that I invest in getting a CAN-OBD II(diagnostics) to spot where the trouble is. Are we in the right direction? Any expert opinions will truly be valued. Help pleeeaasssseee.
Unread 11-17-2009, 11:35 AM   #2
Well, not an expert, but I can offer these suggestions... When was the fuel filter last changed? That should be done yearly. Same with air filter. The fuel pump should also be checked, although I think that's more in the working/not working category. Vacuum leak?
OBD II didn't enter the picture until the 1996 model year, so I'm rather certain that your car is OBD I. I don't know if OBD II incorporates I, so if you go that route be sure to check exactly what you need before shelling out money.
Unread 11-18-2009, 07:26 PM   #3
macky55e34lover
i already replaced the fuel filter and air filter, fuel pump i agree needs to be checked, how about the crank sensor? is it connected to the problem?
thank you very much!
Unread 11-18-2009, 11:14 PM   #4
Don't ask me to explain it, but if the crankshaft position sensor doesn't send a signal to the engine control module, then it's a no-go. So that could be the problem. I think it can be checked electronically to see if it's functioning properly.
Unread 11-22-2009, 06:28 AM   #5
macky55e34lover
Thank you very much man! I will have it checked this week! OBD-the works, everything
Unread 02-28-2010, 03:54 AM   #6
macky55e34lover
thank you for all of the advice, had the computer checked - no faults on this, the problem was pinpointed to the fuel pump and the crank sensor as well, i changed the air carbon canister as well as i can smell fuel in the car. the car runs sweet now.
Unread 08-18-2011, 06:01 AM   #7
LindaWens
Your Ride: Camry
thank you for all of the advice It's really useful.
baltimore bmw
1986 e30 intermittent starting problem...plz help!! black325es E21, E30 3 07-22-2009 07:11 PM
E30 Problems: Hard Starting and Steering Noise BMWFreak E21, E30 0 03-08-2008 02:29 AM
MAJOR PROBLEM - Starting Car!!!! HELP!!! projal147 E36 12 09-07-2006 11:18 AM
M50 Manifold komodo E36 43 05-22-2005 07:31 PM
