Unread 10-13-2009, 03:17 PM   #1
E34Cruiser
Your Ride: 1991 E34 525i
Question Suspect Water Pump
Ive noticed some dripping of coolant down the front of the engine, I suspect the coolant pump........
Is there anything i could do to confirm this and is it easy as the bentley manual makes out... also any tips would be good.
cheers guys
Unread 10-13-2009, 04:59 PM   #2
Could well be. Two direct quotes from Bentley: 1)"The coolant provides lubrication for the pump shaft, so an occasional drop of coolant leaking from the pump is acceptable. If coolant drips steadily from the vent hole, the pump should be replaced." 2)"Inspect the coolant pump by first removing the drive belt from the pump. Firmly grasp opposite sides of the pulley and check for play in all directions. Spin the pulley and check that the shaft runs smoothly."
If the pump does need to be replaced, be sure to use the updated metal impeller type, although I think the old style plastic ones are no longer on the market.
It's a reasonably straightforward job, depends upon how much time you want to spend, whether you're willing and able to put up with draining and refilling the cooling system.
FS: e34 Auxilary Water Pump e39 bimmer Bmw Cars For Sale/Wanted 1 11-03-2011 12:36 PM
e30 water pump wolffy16 E21, E30 1 12-15-2008 07:22 PM
==> Water pump broke off while I was removing it... ecks E36 0 09-13-2007 01:59 AM
Advice on new DIY project... E30 M10 water pump mullethunter3 E36 16 12-13-2006 10:29 PM
