Unread 10-12-2009, 06:07 AM   #1
wessamkamel
wessamkamel's Avatar
Your Ride: bmw 330i 2001
Dear Friends I need and urgent help for my 330i 01 headlights,
I got an accident last month in the front left side and I have changed the headlights to DEPO with angel eyes, the car stays at the garage for one month for repairing and when we are checking the new DEPO lights every thing was fine for few minuets and then the R side angel eyes started flashing and switched off and the corner lights came ON and the dash warning lights also came ON after some more minuets the L side started flashing in the same time the xenon lights was flashing together in the same time, I have changed the battery with new one today and the problem still same, kindly advice me ASAP what I have to check??
Regards to ALL,
Wessam,
Unread 10-12-2009, 04:00 PM   #2
Check all the power and ground connections, clean tighten etc. You may have lost or had a grounding strap damaged in the accident.
Unread 10-14-2009, 06:17 AM   #3
wessamkamel
Dear Evil,
Thank your for your reply, I have checked all the wiring and its OK, and grounds also OK, I forget to tell you that I have connected the AE to the DRL of the headlights (the small lights inside the headlight) and I have disconnected one side of the AE and I connected a normal 5w lamp and every thing goes fine, the problem is coming only when I connect the AE to the DRL and I this that the resistance of the AE is different that the normal bulb,
So is there is any way to connect the DEPO AE to the DRL original socket of the car,
Thank you again for helping me,
Regards,
Unread 10-14-2009, 09:45 PM   #4
Ya got me, but continuing the way you are the flickering lights would indicate a module getting slowly toasted
