Unread 10-08-2009, 12:54 PM   #1
tomdavisnc
Your Ride: 2003 325xi
front Wheel Hub/Bearing Removal help 2003 325xi
When I try to remove the Hub/Bearing assembly, the entire casing attached to the control arm and strut come off with the Hub. Did not want to remove the strut and the control arm. Should the hub/bearing assembly come out or is it pressure fitted into the casing as well?
Any help or advise would be great. The manuals make it sound easy but maybe they are the i and not the xi directions.
Unread 11-18-2009, 01:42 PM   #2
BimmersGarage
Your Ride: 330i
Send a message via Skype™ to BimmersGarage
Cool front Wheel Hub/Bearing Removal help 2003 325xi
Here's a video for removing the Hub/Bearing on a 330i. Perhaps it'll give you some more insight on what to do.
http://www.youtube.com/watch?v=OU2xSBvXA5g
Hope it helps. Good luck!
DIY: E30 Front Wheel Bearing Replacement mullethunter3 BMW OEM Parts Department DIY's & FAQ's 14 12-20-2014 07:22 AM
Front wheel bearings disco48 BMW OEM Parts Department DIY's & FAQ's 0 01-30-2008 01:30 PM
Audio improvements for 2003 325xi Cook1305 Car Audio and Electronics 4 10-31-2007 05:16 PM
325xi front wheel bearing replacement LynnFlores M3 5 04-07-2006 04:47 PM
Wheel Lock Removal Ghetto mode DIY! (Mcgard) defkon99 BMW OEM Parts Department DIY's & FAQ's 9 02-13-2006 05:51 PM
