Go Back   United Bimmer Community - BMW Forum > UnitedBimmer- Model Categories > 6-Series (E3, E24, E63, E64)
6-Series (E3, E24, E63, E64) General discussion and technical help for all year 6 series cars.
Unread 09-02-2009, 09:00 AM   #1
timo
Your Ride: 85 635csi
quick questions about valve adjustments.anyone
I'm planning on doing a valve adjustment on my 85' 6 & need to find the adjustment specs. Can anyone give me a starting point? thanks
Unread 09-02-2009, 02:02 PM   #2
scooter
scooter's Avatar
Rate My Car: 296 / 340
Your Ride: 99m3
The valve lash adjustment spec is 0.012 and the actual adjustment is using the eccentric that forms part of the rocker. All you do is loosen the locking nut a tad and move the ecentric to either tighten or loosen the spec. The hardest part is rolling the engine over. I do this by pulling the plugs out and using a BFW on the alternator nut. Just a little down force on the belt and she goes right over.
What they are refering to about overlap with the cam profile is pretty basic. What you are doing is putting the valves in the closed position by putting another in the open position. figure 40 shows the precedure just about as anyone can for adjustment. It's rather simple once you get to the valves. Just remember that every cylinder in the engine is 180* out from another which the chart shows for example #6 is overlaped -both valves open-when #1 is closed.
Unread 02-10-2010, 09:18 AM   #3
bmwlove100
Title: Read Only Club
Your Ride: BMW Z3
nice thanks
Replacing valve covers, leaking oil 740iguy 7 Series (E23, E32, E38, E65, E66) 3 02-07-2009 01:14 PM
Auxiliary Air Valve Vacuum Line gksailor E36 0 11-18-2008 10:09 AM
Few quick questions ccfc1927 E36 6 02-29-2008 03:39 PM
Quick Questions on E46 Turbo/superchargers Numark318i E46 3 01-25-2006 03:04 PM
2 Quick and General ABS questions... delmarco E36 4 08-06-2005 03:34 PM
