Unread 04-18-2005, 12:51 AM   #1
the afro guy
Name: the afro guy
fat sway bars... who has them?
i'm thinking of getting some fatter sways for the e30. anyone got them? how much of an impact did it make and what was the effect? better turn in? any under/over steer?
Unread 04-18-2005, 06:44 AM   #2
hamann318is
Rate My Car: 99 / 340
Send a message via AIM to hamann318is
If you just upgrade rear sways, there will be more oversteer.
If you just upgrade front sways, there will be more understeer.
You might want to look at upgrading with factory goodies. For your car, they have the front E30 Cabrio bar (22mm) and the E30 M3 rear bar (14.5mm). However, I'd just upgrade the rear bar and see how you like that, because installing both might offset your handling dynamics and give you more understeer.
The BMW 318 is back. With a vengeance.
Unread 04-18-2005, 11:25 AM   #3
spiff
Send a message via AIM to spiff
www.seambmw.com
they sell the Ireland Engineering sway bars.
they are 25mm in the front, and 22mm in the rear, and they are freaking awesome, and you really really feel the difference. Ive heard only good things about them, and they are like 425$ for the set i believe, and it comes with all the parts(ofcourse)
tougeFaction
"You've got to fix the nut behind the wheel before you start fixing the bolts on the car"
Proud member of The "First 10 Members Playaz" Club
Founder and Proud member of The "Ran from a Cop and Got away" Club (x6, and counting)
I with GotKraut religiously via AIM.
Unread 04-18-2005, 11:28 AM   #4
cruzin 323is
Send a message via AIM to cruzin 323is
away bars in general are the best suspension upgrade that u can do...
Unread 04-18-2005, 12:33 PM   #5
Ciscokid
Send a message via AIM to Ciscokid
you can find a pretty good deal at turnermotorsport.com
they have a set for $309 that includes a 22mm front and a 19mm rear.
http://www.digitalmediamemories.com/...mw/kennedypark
Pics
"Leave the gun, take the cannolis"
Help a fellow BMW driver out:
Unread 04-20-2005, 08:08 PM   #6
///M Power
Rate My Car: 26 / 340
Your Ride: 95 m3 turbo
I just posted in another topic about this.
Originally Posted by ///M Power
Your car already has sway bars. They really aren't that thin. No, they are not worth it as your first suspension modification. You should save up for springs/shocks or coilovers if you really want to feel a difference. I added aftermarket sway bars after my shocks and springs and barely noticed a difference, but rather lowering the car with stiffer shocks helped far more than anything i've ever added. A strut tower brace is not worth it as a first modification aswell. Beware that stifferening up the body too much can actually hurt your performance. Also, the only truly effective strut tower brace is one that is welded to the strut towers.
Save your money.
Unread 04-25-2005, 11:06 AM   #7
the afro guy
Name: the afro guy
cheers guys i'll look into it. i'm probably going to look for something locally. shipping anything to australia is expensive so i'll get a few ideas of what works well and go from there.
i am god.... i know this because one day i was praying and discovered i was talking to myself
Unread 04-25-2005, 02:08 PM   #8
///M Power
Cheers indeed after looking at your newly updated mod list it has become apparent that sways would be the next obvious choice. Good Luck!
Unread 04-25-2005, 08:46 PM   #9
austin
Rate My Car: 153 / 340
Send a message via AIM to austin
i got those, and im very satisfied
1999 528iA
1998 318ti California Sport
M5 Sway Bars installed dinan540 E12, E28, E34, E39, E60 0 03-08-2006 08:15 PM
Sway Bars Vs. Tower Bars Numark318i E21, E30 8 02-10-2006 01:02 PM
8 Series sway bars TerryY Tire, Wheels And Suspension Forum 5 08-31-2005 09:25 AM
sway bar mounting B_w. E36 7 04-30-2005 01:14 PM
Sway bars? Rooz Tire, Wheels And Suspension Forum 29 04-25-2005 08:45 PM
