Unread 08-25-2009, 10:28 PM   #1
zach22
Your Ride: 2002 325i
Ignition problems/ STARTER??? IDK
So the other night after leaving a meeting, I couldn't start my car. Its done this before on different ocasions. but just a lil smack of the key or placing the key in the ignition and charging it for a couple seconds then turning over the car. But now it will turn on all the dash lights and the battery is at a 12.4 charge(good) so im thinking its the key sensor or it is the starter??? The key will turn the ignition but wont try and turn over at all, and I do hear a click every time i try and turn it down under the intake manifold behind the alternator which is where the starter is located i think.
If anybody has had similar problems or is a tech and has some usefull information I would greatly apreciate it.
Zach
Unread 08-28-2009, 01:12 PM   #2
doughboyea
doughboyea's Avatar
Your Ride: 2007 Acura TSX
Send a message via AIM to doughboyea Send a message via Yahoo to doughboyea Send a message via Skype™ to doughboyea
I had a problem in my old Benz a few years ago. It was hard starting at first. Then, as I drove at night, things slowly began to turn off. In order: radio, heating, interior lights then, eventually, head lights. The car still drove. By the time I reached the bottom of the driveway, the engine stalled out. My battery was fine, but it was my alternator that was the problem.
Its not exactly similar to yours, but perhaps applying a volt meter to your alternator (or starter) would better locate the issue. That's what I did. Good luck.
Dough
Current Ride
2007 Acura TSX w/Navi
Past rides:
1999 BMW 328i E46 Dinan Stg. 1
1989 Mercedes 190E 2.6
1980 Mercedes 240D
Unread 08-28-2009, 07:36 PM   #3
Sounds like a dying relay or key switch. Could be a key reader. Have you installed anything or changed anything before it started happening?
Spinning Ignition barrel repair David Mc E36 12 10-05-2011 10:00 AM
Engine Problems BMW325AD E46 1 07-27-2009 11:17 AM
E30 Problems: Hard Starting and Steering Noise BMWFreak E21, E30 0 03-08-2008 02:29 AM
No Battery Voltage to Starter singring E36 2 01-09-2006 10:20 PM
