Unread 07-04-2009, 04:46 PM   #1
sandersnsandy
sandersnsandy's Avatar
Your Ride: 1997 740i
Power steering leaking
I finely found my leak. Its the banjo bolt on the power steering box.It has aluminum washers to seal the unit.I tried to fix with copper washers but it still leaks(couldnt find any aluminum ones) If I get the right washers put on will this stop the leak? or is there another problem that I should be looking at?
Unread 04-08-2010, 03:18 AM   #2
RusserEST
Your Ride: 1999 BMW 728 i
Most common problem is in rubber house's. U need to remove 1 cm from house end and re-tighten them. Wash off leaked oil and see, if that helped.
Control Arm or Power steering?? tree36 E36 5 11-07-2010 10:44 PM
Could use some guidance Door locks, power steering issues new2330i E46 0 12-31-2008 12:35 PM
Power steering problems f1indycar E46 3 12-09-2007 11:14 PM
Changed My Power Steering Fluid Numark318i BMW OEM Parts Department DIY's & FAQ's 2 11-01-2007 01:59 AM
