Unread 06-30-2009, 11:39 AM   #1
doughboyea
doughboyea's Avatar
Your Ride: 2007 Acura TSX
Send a message via AIM to doughboyea Send a message via Yahoo to doughboyea Send a message via Skype™ to doughboyea
Service Manual, let me know what you want to know.
I've noticed at least one person asking for the manual for the E46. I have it, and although I do not plan to part with it, I am offering to aid those in their repairs.
So, let me know what you want to do, I'll look it up and type it out in here. If it's alot of typing, a PDF may be made. Manual covers all US-Spec pre-facelift E46 models (1999-2001) except the M3.
I'm really bored since getting laid off.
Dough
Current Ride
2007 Acura TSX w/Navi
Past rides:
1999 BMW 328i E46 Dinan Stg. 1
1989 Mercedes 190E 2.6
1980 Mercedes 240D
Unread 07-03-2009, 01:37 PM   #2
doughboyea
doughboyea's Avatar
Center Console Window Switch Replacement
Originally Posted by Diane View Post
Good morning everyone!!
My 2003 325ci drivers window switch(the buttons) are broke.I understand that I need to purchase the complete window switch. Does anyone know any sights that will explain how to access the console to replace this switch? I've searched th internet with not much luck!!
Your BMW is a 2003 model year, however, the procedure should be rather similar. When referring to locations of components, I try to make them in relation to their installed position:
Lower Dashboard/Console Switches, replacing:
-Remove shift knob by pulling knob straight off the gearshift lever. NOTE: Removal of the shift knob will require about 90lbs of force. Do not twist knob or locating key can be damaged.
-Pry up on rear of shift boot/bezel to unclip, then remove boot from front retainers.
-Remove retaining screws under transmission selector boot/trim located at the rear of the opening.
Power Window Switches, Replacing:
-To remove the left or right ganged window switches:
Shifter Bezel: Lift up by prying gently.
OR
Shifter Boot: Unclip bottom of boot from center console trim by pushing forward. Pull boot up around shifter, but DO NOT remove.
-Unclip the switch retainer from the rear and pull out switches from under the console trim. Detach the electrical harness connector from the bottom of the switches.
-Installation is the reverse of removal.
Source: BMW 3 Series Service Manual, Bentley Publishers, Page 612-7
Dough
Current Ride
Past rides:
1980 Mercedes 240D
Unread 07-07-2009, 07:26 AM   #3
Diane
Diane's Avatar
Your Ride: 2003 325ci
Smile Thank you
You're the best !!! Thank you so much for the repair procedure, it all went well and the windows work just fine. I apprecaite your help! Oh, by the way.... now the drivers tail lamp is out... any ideas on how I change that? Anyway, you have a great day and once again ...Thank You !!
Unread 07-09-2009, 04:06 AM   #4
josephi
Your Ride: 2002 330i
How to replace rear quarter window molding
Hi. I've been trying to figure out how to remove the thin rubber molding that fits around the rear quarter windows of my 2002 330i sedan. It's #7 in the following diagram:
http://="http://www.realoem.com/bmw/...3&hg=51&fg=05"
I've been told that the rubber seal that fits around the top and side of the rear doors and the vertical trim piece that covers the thin pillar between the quarter window and window of the rear door needs to come off to access that seal. I was wondering if you could tell me if the manual shows how to remove those pieces. If you could post those instructions, it would be great, but even just letting me know if the manual shows these steps would be helpful because I would be willing to buy it myself. Thanks!
Unread 07-22-2009, 10:45 PM   #5
glidden
Your Ride: 2000 BMW 323I
hi i need the repair procedure for this code p1188/p1189/p1250 thats from 323i 2000. I change the oil separator(ccv) with all the hose / spark plugs / mass air flow and the check engine light still on .please let me know thanks .
Unread 08-25-2009, 10:35 AM   #6
doughboyea
doughboyea's Avatar
Sorry for my delay, seems I did not subscribe to this thread...
Anyway, Joseph, the Bentley manual that I have is for model years 1999 to 2001. Your 2002 Coupe (I assume) is not covered, however, the following is what Bentley recomends as far as the rear window is concerned in '99 to '01 Coupes:
Dough
Current Ride
Past rides:
1980 Mercedes 240D
Unread 08-25-2009, 11:05 AM   #7
doughboyea
doughboyea's Avatar
Again, I'm sorry for the delay.
The Bentley manual does not show a listing for the codes you mentioned. The appendix does have a listing of a break down of codes, according to the nomenclature:
P = Powertrain
1 = BMW sanctioned issue
1 = Air/Fuel Injection System
88, 89 = "individual circuits or components"
P-1250 would be the same as above but for Fuel Injection instead of Air/Fuel Injection.
Here is the Bentley Appendix: Click Here
Best I can do, sorry.
Dough
Current Ride
Past rides:
1980 Mercedes 240D
Unread 08-25-2009, 11:16 AM   #8
doughboyea
doughboyea's Avatar
Your welcome.
To access trunk lid taillight bulbs:
Dough
Current Ride
Past rides:
1980 Mercedes 240D
Unread 08-25-2009, 12:35 PM   #9
josephi
Dough
Hi. I appreciate the response! However, I have a 330i Sedan, not a Coupe. I think the 99-01 models and 2002 models are similar in respect to most of the body parts, from what I can see. Does the Bentley manual address the rear quarter window for the sedan? Thanks again.
Unread 08-25-2009, 06:45 PM   #10
rhstratboy
Your Ride: 2000 328i
Backseat removal
I have a 2000 328i I'm needing to know how to remove the backrest portion of the back seat. I think I have the same service manual but there is nothing about backseat removal in it. Thanks
Unread 08-25-2009, 06:51 PM   #11
doughboyea
doughboyea's Avatar
I was afraid of that, unfortunately, there really isn't anything substantial for that window. On page 512-7, the manual details how to remove the anti-trap strip around the rear window.
For most of the procedures involving windows, the manual states to remove the door panel (being careful of any airbags, disconnect battery). Then detaching the window frame molding strip between the rear window and the fixed corner window by peeling the strip off being careful to not tear the strip at the top by the anti-trap strip. Once removed, it can be assumed that you would be able to remove that fixed glass and sealant. Beyond that, there isn't anything else. Sorry.
Dough
Current Ride
Past rides:
1980 Mercedes 240D
Unread 08-25-2009, 06:56 PM   #12
doughboyea
doughboyea's Avatar
If you have the same manual (ISBN: 0-8376-0320-X), see page 520-7. It's a single pager, not much information, but gives you a few steps to go through. Let me know if you need it.
Dough
Current Ride
Past rides:
1980 Mercedes 240D
Unread 08-25-2009, 07:01 PM   #13
rhstratboy
Thanks I don't know how many times I looked through this manual and there it is.
Unread 11-25-2009, 08:07 AM   #14
doughboyea
doughboyea's Avatar
Selling
Need to sell this manual, see here: Classifieds, Bentley Service Manual
Dough
Current Ride
Past rides:
1980 Mercedes 240D
Unread 07-07-2010, 01:45 AM   #15
Wofy
Your Ride: 2001 E46
Hi, if possible i need the wiring diagram of the E46 318i (same as the 328i) for the ignition key general power diagram.
Thx
Marco
cd/radio owners manual Mack033 E46 1 03-07-2007 04:14 AM
Oil Service light? Alpine328i E36 13 03-05-2007 01:20 PM
Service Manual Suggestions wstull E36 1 10-13-2006 08:13 AM
Ferrets Are Service Animals Too komodo United Off Topic  **FOR MEMBERS ONLY** 2 10-04-2005 11:12 AM
